69 Road Runner Air Grabber A4 Platinum
#573682
01/05/10 10:44 AM
01/05/10 10:44 AM
Posts: 388 Michigan
SD800
I was given a 69 RR that someone was going to turn into a race car. they cut out the inner fenders and that is as far as they got.When I got the car it had no hood with it and of course the Fender Tag is gone. the car was built at the Los Angeles plant and from what I have been told they did not put Build Sheets in the car at that plant. So... I want to restore it back to as close to original as I can and would like to know what I need to look for as far as signs this was an air grabber car, where was the Air Grabber handle mounted and would there be specific holes in the dash or fire wall? The car was originally A4 with Black interior and had the partially blacked out hood, I can see where the stripes started after I removed the windshield.The car had 3 repaints and under all the seals, gaskets and rear package tray and under everything else I removed it is A4 Platium silver. The Vin say it was a 383 car RM23H9E and it is a 4 speed car, factory installed 4 speed hump and same black sealer around it as the rest of the seams. also has the orange reverse light on the dash. It's a bench set car, no holes by the tunnel for the buckets to bolt down. the interior was pretty complete except both front and back seats where missing, it also has the shoulder harness's
Anyway back to the airgrabber, the hood was sold so if someone was converting their car to an air grabber they may have removed all the parts.
What other options where available on this car? would it be possible to verify options and have a fender tag made for it? I would like to have the tag for myself and NOT for resale this car will only be sold after I'm ten toes up
You'll have plenty of time to sleep when your dead, let's go
Re: 69 Road Runner Air Grabber A4 Platinum
[Re: SD800]
#573683
01/05/10 01:57 PM
01/05/10 01:57 PM
Posts: 3,624 Fort Worth, Texas
xs29j8
Fort Worth, Texas
A nice clean "factory" Air Grabber control cable routing hole in the firewall (slightly on the passenger side) is the best indicator if no fender tag or broadcast sheet exists. I do not have a picture of the location handy, but can get one this weekend if none are posted... Here is a thread on my A4 Road Runner, but the hole location is not visible... https://board.moparts.org/ubbthreads/show...part=1&vc=1 Pics of the A4 4Spd RR?...
[Re: xs29j8]
#573684
01/05/10 02:11 PM
01/05/10 02:11 PM
Posts: 388 Michigan
SD800
Is this the hole location for the cable
[Re: SD800]
#573685
01/05/10 02:22 PM
01/05/10 02:22 PM
xs29j8
Fort Worth, Texas
Yep, I believe it is... good eyes!
[Re: xs29j8]
#573686
01/05/10 03:17 PM
01/05/10 03:17 PM
Posts: 388 Michigan
SD800
I believe my car has that hole in the firewall, I'll check tonight.Thanks for your help
[Re: QuickSilver]
#573688
01/05/10 07:36 PM
01/05/10 07:36 PM
Posts: 1,495 Fort Workin Tx
Day2Runner
Fort Workin Tx
B5 N96 69RR air grabber handle should have 2 holes on the right side of the ash tray on the lower edge of dash frame I think. Allen ??
[Re: Day2Runner]
#573692
01/05/10 10:06 PM
01/05/10 10:06 PM
xs29j8
Fort Worth, Texas
Great picture Dan! I was thinking left of the ash tray... between the ash tray and the steering column. I believe that the control "handle" (vent cable control with red "CARB AIR" placard) is hidden behind the FM Converter in this old picture...
[Re: xs29j8]
#573693
01/06/10 10:46 AM
01/06/10 10:46 AM
Posts: 388 Michigan
SD800
Checked last night, no Air Grabeer cable hole in the firewall. Bummer it's not there but cool, I won't need to buy all those expensive parts.
Is there any way to tell what wheels and tires may have came on the car from the factory? Like if they were part of a decore package and if the car did not have said package you got steelies and hub caps
[Re: SD800]
#573695
01/06/10 11:00 AM
01/06/10 11:00 AM
Posts: 388 Michigan
SD800
Thanks for the help you guys, anything else you can think of that I should look for on this car that would tell me what options in may have had?
