Oil supply to roller lifters ? #573593
01/05/10 06:52 AM
01/05/10 06:52 AM
Australia
gg408 Offline OP
gg408  Offline OP
Australia
What size oil hole should you have in bushed lifter bores for roller lifters.
I have a .040" hole in mine is that big enough?
Cheers
GG408
Re: Oil supply to roller lifters ? [Re: gg408] #573594
01/05/10 08:23 AM
01/05/10 08:23 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Cheers
GG408
That sounds about right
Re: Oil supply to roller lifters ? [Re: gg408] #573595
01/05/10 10:44 AM
01/05/10 10:44 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Will you be running pushrod oiling ?
Re: Oil supply to roller lifters ? [Re: JohnRR] #573596
01/06/10 01:33 AM
01/06/10 01:33 AM
Australia
gg408 Offline OP
gg408  Offline OP
Australia
No its std through the block and heads oiling.
Cheers
GG408
Re: Oil supply to roller lifters ? [Re: gg408] #573597
01/06/10 01:43 AM
01/06/10 01:43 AM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
Cheers
GG408
Then no hole is needed. Drainback, windage, splash, etc will be enough to keep the lifter lubed.
Edit unless you have pressure fed axles.
Re: Oil supply to roller lifters ? [Re: TS3303] #573598
01/06/10 02:34 AM
01/06/10 02:34 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Post deleted by Defbob [Re: go green] #573599
01/06/10 03:51 AM
01/06/10 03:51 AM
Re: Oil supply to roller lifters ? #573600
01/06/10 07:23 AM
01/06/10 07:23 AM
Australia
gg408 Offline OP
gg408  Offline OP
Australia
Thanks.
Cheers
GG408
Re: Oil supply to roller lifters ? [Re: gg408] #573601
01/06/10 07:39 AM
01/06/10 07:39 AM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
How are you handling pushrod cup oiling at the rocker arm?
Is this race only or will it see some street time?
Re: Oil supply to roller lifters ? [Re: HemiDave] #573602
01/08/10 05:55 AM
01/08/10 05:55 AM
Australia
gg408 Offline OP
gg408  Offline OP
Australia
Street/Strip eng, using HS roller rockers they seem to have oil supply hole to adjusters.
Hope that works.
Cheers
GG408
