Timing chain tensioner for SB stroker ? #572791
01/04/10 08:41 PM
01/04/10 08:41 PM
USA
K
krw71ragtop Offline OP
K
USA
Just wondering who is using a tensioner and why I should or shouldn't use one ?
Re: Timing chain tensioner for SB stroker ? [Re: krw71ragtop] #572792
01/04/10 09:01 PM
01/04/10 09:01 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I am using 1 so far nothing bad to say about it. If you are going to use 1 make sure its in place when you degree the cam.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Timing chain tensioner for SB stroker ? [Re: dusturbd340W5] #572793
01/04/10 10:01 PM
01/04/10 10:01 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I had the Mopar one in my 474 small block stroker. Never any issues. I heard it is made by melling in case you can get that one easier/cheaper.
SRT DEMON ONE SEAT
Re: Timing chain tensioner for SB stroker ? [Re: krw71ragtop] #572794
01/04/10 10:43 PM
01/04/10 10:43 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
I've used one 2 seasons so far, no problems yet
Re: Timing chain tensioner for SB stroker ? [Re: Lil Wedge] #572795
01/04/10 10:56 PM
01/04/10 10:56 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
same here.
Re: Timing chain tensioner for SB stroker ? [Re: dartman366] #572796
01/04/10 11:23 PM
01/04/10 11:23 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
I've got one in both of my smallblock strokers. No problems at all... I like that fact that they take up any little bit of slack you have in the timing chain.
Re: Timing chain tensioner for SB stroker ? [Re: krw71ragtop] #572797
01/04/10 11:24 PM
01/04/10 11:24 PM
AndyF Offline
AndyF  Offline
I'm working on a SB motor now that really chewed up the tensioner. I'm going to leave it off for the next build. Not sure why this one got so chewed up but it doesn't look very pretty and it didn't have very many miles on it.
Re: Timing chain tensioner for SB stroker ? [Re: AndyF] #572798
01/05/10 12:12 AM
01/05/10 12:12 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I've only used them if the chain is loose. The PBM labeled billet timing sets for the small blocks flap in the wind for whatever reason, new, out of the box. On the engines we've built with those timing sets we used a tensioner. Now we use Progear timing sets and they don't have any slack. Kinda a pain to get on actually, but I prefer that to the alternative.
Re: Timing chain tensioner for SB stroker ? [Re: dodgeboy11] #572799
01/05/10 12:33 AM
01/05/10 12:33 AM
houston texas
gremlinsteve Offline
houston texas
all the late model hemis in the new chargers and challengers use them.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Timing chain tensioner for SB stroker ? [Re: dartman366] #572800
01/05/10 11:01 AM
01/05/10 11:01 AM
Az
Crizila Offline
Crizila  Offline
Az
same here.
Me 3!
Fastest 300
Re: Timing chain tensioner for SB stroker ? [Re: Crizila] #572801
01/05/10 11:26 AM
01/05/10 11:26 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
RyanJ told me that he uses one in all engines that use a chain instead of a gear drive. My 408 has one.
Re: Timing chain tensioner for SB stroker ? [Re: justinp61] #572802
01/05/10 08:49 PM
01/05/10 08:49 PM
USA
K
K
USA
Thanks for the responses. I'm not sure if I'm going to try a tensioner or go with a gear to gear timing set ? Any opinions on a gear to gear set ? My build will see more street use.
