Re: Throttle cable for 64 B body
[Re: Blue Dodge Bob]
#572290
01/04/10 01:22 PM
01/04/10 01:22 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I used a 73 Dart /6 cable on my 65 440.I needed a longer one with my M1 and Dominator.I did modify the pedal end of the cable so it worked with my 65 Pedal.It was pretty simple to do even though I cant remember how I did it now.If I looked at it I could probally remember. Rocky
Chrysler Firepower
#572292
01/04/10 02:01 PM
01/04/10 02:01 PM
therocks
Niles , Ohio
I had a 73 Dart we scrapped.I remember doing it but cant remember how.Once I had the firewall piece out it was pretty simple to do.Its been in for 2 years and I have heavy dual springs.No problesm and its street driven.Only the pedal part needs mods.I just slipped the cable thru the hole in the firewall and clamped it on the Mancini adapter.Rocky
Chrysler Firepower
#572294
01/04/10 03:48 PM
01/04/10 03:48 PM
For my 64 Polara, I cut off the clevis (or whatever you call it) from my old cable using a cutoff wheel to make a slot just large enough that I could slide the cable through it, then put it on the new cable and used a dab of weld to close the slot (obviously you don't want to weld the clevis to the cable). This setup has worked well for over a decade.
#572296
01/04/10 07:11 PM
01/04/10 07:11 PM
Which throttle cable did you use?
Ha, I sure don't remember, I imagine just your standard-issue 66-up big block replacement cable.
I wonder if I couldn't re-use the old cable housing, etc., and re-string it with new steel cable.
With the right material and tools, I'm sure you could, but you're on your own here . . . .
#572299
01/05/10 09:40 AM
01/05/10 09:40 AM
therocks
Niles , Ohio
413 that might be how I did mine.Hey I had the cable and my stock 65 was too short.That /6 was nice and long and free.I like free.Rocky
Chrysler Firepower
#572300
01/05/10 11:23 AM
01/05/10 11:23 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Did the same with this on my 62,no problems at all and it required a shorter cable because or throttle shaft placement.
#572303
01/05/10 12:37 PM
01/05/10 12:37 PM
therocks
Niles , Ohio
Mine mounted fine at the carb.I dont have any other linkage as I have a 4 speed.Just adjusted it an it was fine.That 62 should of had a rod I believe.My kids 62 300 has steel rod no cable.Rocky
Chrysler Firepower
[Re: therocks]
#572304
01/05/10 01:11 PM
01/05/10 01:11 PM
62maxwgn
Blair County,PA
All inline 2x4's were mechanical,no cable.Changing my 62 to cable was easy.
[Re: wings471]
#572306
01/05/10 01:46 PM
01/05/10 01:46 PM
therocks
Niles , Ohio
The kids 300 is single 4 .He uses my Street Dominator with Holley and his rod linkage it works great.He eliminated the kick down when he went to the CRT full manual trans.Rocky
Chrysler Firepower
