Dart trunk floor #572134
01/04/10 11:31 AM
01/04/10 11:31 AM
Nebraska
Dodge-N-Shelby Offline OP
Nebraska
I have a 74 Dart 4 door with a super clean trunk floor. I am curious if these will work in a 2 door/Swinger. I hate to send it to the crusher if it will work, I would rather take the time to cut it out and put it in storage. While we're at it, how about the front floor pan? This car is undercoated and the metal is as clean as the day it was new, its just a parted 4 door is the only problem. Thanks in advance for any info!
Re: Dart trunk floor [Re: Dodge-N-Shelby] #572135
01/04/10 01:01 PM
01/04/10 01:01 PM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
Same trunk floor as a 73-76 two door Swinger, Scamp, Dart Sport or Duster. Front floor will also work in 73-76 two door Darts, Scamps and Dusters.
Check and see if it has the hump on drivers side of the floor for the catalytic convertor, it would be under the driver side of the front seat near the floor tunnel. This doesn't mean the floor pan won't work in other cars it will just look a little different and will require different seat brackets for buckets seat cars only.
Re: Dart trunk floor [Re: Dodge-N-Shelby] #572136
01/04/10 03:17 PM
01/04/10 03:17 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Trunk floor will work in any 67-76 car. There were some small differences through the years.
Front floor pans, same thing except the 75-76 cars with the cat hump. 74 should not have the cat hump. The floors are basically the same in the front sections regardless of wheelbase.
