Re: Aluminum Stator Convertor and Transbrake
[Re: dusturbd340W5]
#571570
01/04/10 10:02 PM
01/04/10 10:02 PM
dartman366
Mt. Vernon, Ohio
A couple of years ago,I asked Paul at Turbo Action (through Tony aka Quicktree) about using my J converter with a brake.He checked the serial number on it and said "you have a model with an aluminum stator,absolutely do not use it with a brake" So from the man himself,no.
thats kinda funny when I ordered my converter from Paul him self he asked why I wanted a steel stator said it wasn't needed for a brake but I ordered it anyway.
Kind'a gives a person somthing to ponder,,,same person,,two answers.
[Re: dartman366]
#571571
01/04/10 10:11 PM
01/04/10 10:11 PM
Quicktree
totally depends on the hp/torque and combo. if I were going to use a tbrake I would order the steel stator just to be on the safe side like Woody did. even though it may not need it. nice try though.
[Re: Quicktree]
#571572
01/04/10 10:19 PM
01/04/10 10:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
No idea what stator is in my T/A conv... it has about 3000+ trans brake passes on it
[Re: Dunnuck Racing]
#571573
01/04/10 10:47 PM
01/04/10 10:47 PM
Quicktree
hows that converter working for you? haven't talked in a while. didn't you pick up a tenth or so? can't remember.
[Re: Quicktree]
#571574
01/04/10 10:59 PM
01/04/10 10:59 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Hi Tony!, It has been a while,the old J is still holding up well! The Challenger has been through a lot of changes over the last couple years,I don't know where it was at when I talked to you! I used to run a 440 and ran 10.80's or so,last year I put a stroker smallblock in it.So far, 10.21@ 132.We have a little tuning to go yet. The old J converter and 440 are going into the new car I'm putting together for my wife. Thanks for asking! Keith
#571575
01/04/10 11:01 PM
01/04/10 11:01 PM
Quicktree
I was thinking of somebody else. I just checked for you I believe. my memory sucks
[Re: Quicktree]
#571576
01/04/10 11:18 PM
01/04/10 11:18 PM
Posts: 325 IL
Rawone
IL
over 300 9 sec passes on my J conv. Paul also to me NO for the aluminum when I had it restalled, no issues so far...I went with aluminum again. I currently run a PTC though...the J is a spare now.
[Re: 506RR]
#571582
01/06/10 03:54 AM
01/06/10 03:54 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Great info guys. Thank you for all of the replies!
If mine breaks using an aluminum stator, I will report back in and let you guys know.
If it breaks, it will most likely be because it rolled a sprag. That's what usually breaks them. But since the sprags have become more reliable, it doesn't happen as often.
Since I use a spragless converter, I don't even worry about it.
Chris..
