Re: Aluminum Stator Convertor and Transbrake
[Re: dusturbd340W5]
#571570
01/04/10 10:02 PM
01/04/10 10:02 PM
dartman366
Mt. Vernon, Ohio
A couple of years ago,I asked Paul at Turbo Action (through Tony aka Quicktree) about using my J converter with a brake.He checked the serial number on it and said "you have a model with an aluminum stator,absolutely do not use it with a brake" So from the man himself,no.
thats kinda funny when I ordered my converter from Paul him self he asked why I wanted a steel stator said it wasn't needed for a brake but I ordered it anyway.
Kind'a gives a person somthing to ponder,,,same person,,two answers.
[Re: dartman366]
#571571
01/04/10 10:11 PM
01/04/10 10:11 PM
Quicktree
totally depends on the hp/torque and combo. if I were going to use a tbrake I would order the steel stator just to be on the safe side like Woody did. even though it may not need it. nice try though.
[Re: Quicktree]
#571572
01/04/10 10:19 PM
01/04/10 10:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
No idea what stator is in my T/A conv... it has about 3000+ trans brake passes on it
[Re: Dunnuck Racing]
#571573
01/04/10 10:47 PM
01/04/10 10:47 PM
Quicktree
hows that converter working for you? haven't talked in a while. didn't you pick up a tenth or so? can't remember.
[Re: Quicktree]
#571574
01/04/10 10:59 PM
01/04/10 10:59 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Hi Tony!, It has been a while,the old J is still holding up well! The Challenger has been through a lot of changes over the last couple years,I don't know where it was at when I talked to you! I used to run a 440 and ran 10.80's or so,last year I put a stroker smallblock in it.So far, 10.21@ 132.We have a little tuning to go yet. The old J converter and 440 are going into the new car I'm putting together for my wife. Thanks for asking! Keith
#571575
01/04/10 11:01 PM
01/04/10 11:01 PM
Quicktree
I was thinking of somebody else. I just checked for you I believe. my memory sucks
[Re: Quicktree]
#571576
01/04/10 11:18 PM
01/04/10 11:18 PM
Posts: 325 IL
Rawone
IL
over 300 9 sec passes on my J conv. Paul also to me NO for the aluminum when I had it restalled, no issues so far...I went with aluminum again. I currently run a PTC though...the J is a spare now.
[Re: 506RR]
#571582
01/06/10 03:54 AM
01/06/10 03:54 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Great info guys. Thank you for all of the replies!
If mine breaks using an aluminum stator, I will report back in and let you guys know.
If it breaks, it will most likely be because it rolled a sprag. That's what usually breaks them. But since the sprags have become more reliable, it doesn't happen as often.
Since I use a spragless converter, I don't even worry about it.
Chris..
[Re: 540dust]
#571583
01/06/10 11:41 AM
01/06/10 11:41 AM
Posts: 8,165 Left Coast
BobR
Left Coast
Here is the one I've been using the last couple of years.
That's an all aluminum Chance? Not many on this board will to spend 5 grand on a converter. BTW that's the same one we finished the year with.
[Re: 540dust]
#571585
01/06/10 04:02 PM
01/06/10 04:02 PM
BobR
Left Coast
Only the drive cover is aluminum, it was expensive but a fraction of 5g's. If you're trying to win back some money, the right convertor is extremely important. It paid for itself the first season.
Our last one was all aluminum(5 g's). We have one like you do as well(about 2800 if I remember correctly). Not sure how much ET difference there was between the two. There is more aluminum in the trans fluid when we change it in the all aluminum one. We're still not exactly sure what that means. Our deal is about 2500 HP/glide.
