Hi Russ, Long time no see. Thanks for the suggestion.
Thanks. I was looking at the Isky cam's and saw that one.
The cam that I pulled is a little hotter than the stock Commando cam. It Gave good HP and seemed suited for the single-plane intake/Gear ratio that I have. I was also looking at the 390177, but the stock road gears and manual transmission might fall flat on the low end if I do.
If possible, if anyone has the spec book or an old Melling flyer, I might be able to get one made to match. I suppose worst case, I can send the cam in with a request to duplicate it.
--Tom
