cam shaft question #570837
01/03/10 12:40 PM
01/03/10 12:40 PM
S.E. Wisconsin
darepairman Offline OP
S.E. Wisconsin
I have a blue racer cam I bought some years ago. (got out of the car stuff to raise a family)now I am back to building. I have this cam and want to know the mfg date and just what to expect from it in a 318 with 360 heads and .030 over pistons. Here is the info I have, part no. WG-1116, another no. j229, com lift, int. .280 exh, .295 valve lift int. .420 exh .443 advance dur 270 int. 280 exh. any info on this would be appreciated thanks Ed
The Event Horizon is on its way
Re: cam shaft question [Re: darepairman] #570838
01/03/10 04:51 PM
01/03/10 04:51 PM
Welcome here Ed. Does Blue Racer have a website?
Re: cam shaft question [Re: RapidRobert] #570839
01/03/10 05:24 PM
01/03/10 05:24 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Wolverine/Blue Racer Cams
Melling Performance - Duration 278/288 Lift .422/.444 (MTD-1 WG-1116)
Don Guyse
4790 Hudson Road
Osseo, MI 49266
800-248-0134 517-523-3887
Original Camshafts (1954 - 1983)
Re: cam shaft question [Re: RapidRobert] #570840
01/03/10 06:36 PM
01/03/10 06:36 PM
S.E. Wisconsin
S.E. Wisconsin
Thanks Robert, the only website I could find didnt recognize the part no. Snoopy thanks for the contact info. Ed
Re: cam shaft question [Re: darepairman] #570841
01/03/10 11:12 PM
01/03/10 11:12 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
I think that is something close to the order of
the 68' 340 camshaft (might be for the 4speed).
And since there wasn't a intake centerline number
it would be hard to pattern the power range. I
would contact the manufacturer to find out. Good
luck with it.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
