BB Race engine weight.....
#570457
01/02/10 10:52 PM
01/02/10 10:52 PM
Posts: 19,369 Las Vegas
Al_Alguire
Las Vegas
Just curious if you guys have ever weighed your BB race motors..Just curious what you have seen for weights. I will refrain from posting mine til after I see some of the others out there. Mine is a KB aluminum low deck block with B1 heads. I did weight my old World Hemi block and it was 308 especially after weighing the current engine.
Re: BB Race engine weight.....
[Re: Al_Alguire]
#570458
01/02/10 11:08 PM
01/02/10 11:08 PM
Posts: 1,443 Maryland
Dads426
Maryland
My college buddy was a SB guy and referred to the RB motors as "Road Blocks" because they are so fricken heavy (and that was before aftermarket blocks). Don't have a scale capable of weighing one. Will be interested in the reponses.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Al_Alguire]
#570459
01/03/10 12:02 AM
01/03/10 12:02 AM
Posts: 5,875 communist bloc of new jersey
jamesc
what was on it when you weighed it Al (intake, carb, oiling system, cam drive, steel/aluminum rods, etc.)? i'm curious as i'm building a similar setup but a raised deck. the b1 heads are no lightweight for aluminum heads there's a lot of material there
[Re: jamesc]
#570460
01/03/10 12:10 AM
01/03/10 12:10 AM
Al_Alguire
Las Vegas
Complete....As it goes in the car. I only know because we have it out know while doing some painting. Just put it on the scales...
[Re: Al_Alguire]
#570461
01/03/10 01:21 AM
01/03/10 01:21 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
Everything less carb, world Aluminum block, B1 heads, oiling system, air pump, w/pump, dist, ect. in the plastic crate 45# for the crate, no oil, water, 685#'s
[Re: camastomcat]
#570462
01/03/10 10:23 AM
01/03/10 10:23 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I never have weighed the whole package, but the crank is 70 lbs, the machined 4.500 mega block came in at 250 lbs, and the injection is light. Terminator is about 1/4 the weight of a dominator. Rods, 910 grams.
[Re: gregsdart]
#570463
01/03/10 10:49 AM
01/03/10 10:49 AM
Posts: 6,314 The Swamp
MegaDart
The Swamp
not when you add in all the other parts needed to perform the same task. Ie, dist. block, lines and nozzles, leanout valves, etc.
Don't really know what my alum. head bbc's weight but on oak pallet with plywood sides and top, engine cradle carb to pan with trigger, vac pump, etc. topped 800# shipping weight.
[Re: jamesc]
#570464
01/03/10 08:40 PM
01/03/10 08:40 PM
Posts: 1,288 Oregon
sg66mopar
[Re: sg66mopar]
#570465
01/06/10 12:56 AM
01/06/10 12:56 AM
Al_Alguire
Las Vegas
Sorry guys I forgot about this one. I came in just a tick over 500lbs, everything but water.
