Dominator on the street, power valve or not #570315
01/02/10 08:56 PM
01/02/10 08:56 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
I am running 8896-2 on the street. 500' 440-3 intake. Idle and midrange runs eye burning rich. I am running a progressive linkage and front butterflies open 1/3 before the rears start to open. Carb originally came with 1 to 1 soft progressive.I am running a 4.5 power valve in the front. plug in the back. Found my number 1 & 2 spark plugs black, back six are brown. Idle screws all 4 are set for highest vac. Could using a power valve be causing this? I have an air bleed assortment but have not changed anything yet. Wide open jetting is close. Its idle to about 3500 thats rich. Timing is at 36, have tried it all over the place, it seems to like 36. I am running an aftermarket 10degree bushing in msd with light springs. Idle timing is 26. Galen
Re: Dominator on the street, power valve or not [Re: galen] #570316
01/02/10 09:53 PM
01/02/10 09:53 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Ran the same carb on my old 496. I found that the transfer slots were feeding too much fuel. That's a 3 circuit carb so as soon as you get into cruising rpm the transition tubes start to feed fuel making it too rich. I drilled the transfer holes bigger in the main body and hammered in a brass air bleed and opened up the hole to about .082".
I ran a power valve. Since the carb has no vacuum port you will need to rig something up to read your idle/cruise vacuum and set up the power valve accordingly. I blocked the rear power valve off and jetted up accordingly.
Start with air bleeds up to stock to start. You may want to lean the idle and transition circuit slightly leaner.
Re: Dominator on the street, power valve or not [Re: galen] #570317
01/02/10 09:54 PM
01/02/10 09:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats your primary jetting
Re: Dominator on the street, power valve or not [Re: MR_P_BODY] #570318
01/02/10 10:04 PM
01/02/10 10:04 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I had BIGS dominator on my 500" challenger with the indy 440-3. ran great on the street! 4.5 power valve / jet extensions. I was pulling 9"'s of vac was 86f and 94r last pass at the track and was lean at 13.8 at WOT still... went 10.6 @ 128.3 on pump gas before the rain came
http://www.youtube.com/watch?v=gz-szQ1yrgY
Mopar Performance
Re: Dominator on the street, power valve or not [Re: MR_P_BODY] #570319
01/02/10 10:06 PM
01/02/10 10:06 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
primary is 88 Mike
Re: Dominator on the street, power valve or not [Re: galen] #570320
01/02/10 10:07 PM
01/02/10 10:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
primary is 88 Mike
Thats pretty fat for having a PV
Re: Dominator on the street, power valve or not [Re: MR_P_BODY] #570321
01/02/10 10:13 PM
01/02/10 10:13 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Mike it came with 6.5s front and rear with 88 jets squared. Do the main jets effect the idle off idle mixture?
Re: Dominator on the street, power valve or not [Re: galen] #570322
01/02/10 10:18 PM
01/02/10 10:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My 8896 came with 88s squared and no PV... off idle
it starts on the mid
Re: Dominator on the street, power valve or not [Re: MR_P_BODY] #570323
01/02/10 10:41 PM
01/02/10 10:41 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
my 8896 92-94 jets no p/v
1.39 9.85 - 137 mph
Re: Dominator on the street, power valve or not [Re: Ari440] #570324
01/02/10 11:04 PM
01/02/10 11:04 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
OEM jetting. Your's is oem jetting at 88 primary and secondary with P/Valves. Where does the -2 suffix come from? There isn't a part # on Holley or Summit site?
Re: Dominator on the street, power valve or not [Re: galen] #570325
01/03/10 12:15 AM
01/03/10 12:15 AM
65HemiCoronet Offline
I'd be very interested in what others are running, as I have the same setup and results on my 528 hemi. Plugs are very black, almost wet running at cruising speeds. I put larger primary air jets in to try and help some. Haven't really looked at anything else yet. Am wondering if it would be just better throwing in the towel with the dominater and going to 1000 or 950 style 4150 carb?
Yeah, it's got a hemi........a REAL hemi.
Re: Dominator on the street, power valve or not [Re: Ari440] #570326
01/03/10 10:24 AM
01/03/10 10:24 AM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I had mine down to 83 with the PV in the front and 88 or 90 in the rear with no PV. Mine came with 88 square and a powervalve. I thought that was too rich.
Re: Dominator on the street, power valve or not [Re: torkrules] #570327
01/03/10 11:13 AM
01/03/10 11:13 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I have a single 9375 1050 Dominator, jets are 96 squared with no power valve, but if I'm just cruising for a couple weeks without racing I throw a power valve in the front and jet the front down 8 numbers, makes it run MUCH smoother through 1st gear at slow speeds on the street.
Re: Dominator on the street, power valve or not [Re: torkrules] #570328
01/03/10 11:27 AM
01/03/10 11:27 AM
New York
polyspheric Offline
polyspheric  Offline
New York
1 irritating problem with 3 circuit carbs is that the point of tip-in for the intermediate is the position of the hole in the body vs. the sweep of the throttle disc (not RPM or vacuum). This means that different engines size, static CR, cams, plenum volumes etc. need not only a difference hole size, but the hole "bumped" a bit forward or back to change the throttle disc angle at which the hole is exposed to vacuum.
IMHO some have already done this, but are not telling.
If you examine a "suspect" carb, look for a partial bevel or flat spot on the disc's edge where it passes the holes...
Boffin Emeritus
Re: Dominator on the street, power valve or not [Re: Leigh] #570329
01/03/10 11:52 AM
01/03/10 11:52 AM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Ran into the same problem with mine. No one could tell me what the -2 meant. It was stamped "HP" on the side.
Re: Dominator on the street, power valve or not [Re: torkrules] #570330
01/03/10 01:23 PM
01/03/10 01:23 PM
Wisconsin
BIGS Offline
BIGS  Offline
Wisconsin
The great Dominator idle and part throttle rich condition....This is an issue no doubt....we started to adress this issue in 2002 when we started really seeing allot of big "race" type engines being used on the street....
We made several attempts in the early years to try and bandaid this problem with so-so results....and we have been constantly making advances since...
In 2007 we started working more with the 2 circuit theory that has been around for a long time but most didnt want to here about it because the "3 circuit" carb would make more power on the track....but remember were not talking 100% track cars here so if we gave up 10 HP somewhere and in trade gained a clean idle and cleaner cruise our customers would be happy with that.....
We seen instant results with our 2 circuit carbs and knew it was going to be a great carb for street cars that cruise allot....and since then we have have not only made a great cruising/idleing carb but we also have it worked into our race line-up and they run just as fast as the 3 circuit stuff we build and have a clean cruise up the return road and in the pits.....
So if you have an engine that needs the Dominator at wide open for Peak ET/HP you dont have to give up and go back to a 4150 to get a clean running carb....all the mods that you see other racers making to these carbs are on the correct path but it can make you pull your hair out.....
Jesse @ BIGS!!
Jesse & Lynn BIGS Performance Products Building Street/Strip Carburetors since 1974 www.bigsperformance.com
Re: Dominator on the street, power valve or not [Re: galen] #570331
01/03/10 01:31 PM
01/03/10 01:31 PM
AndyF Online content
AndyF  Online Content
Buy yourself some billet metering blocks so you can tune the carb. A Holley three circuit Dominator probably needs to have the intermediate circuit reduced by about 80% to run it on the street at part throttle. Get yourself a wide band setup so you know what your AF ratio is.
An 8896 is not designed to be a street carb. If you're going to try to run one on the street then you need to at least be prepared to completely retune the fuel circuits. You are trying to make that carb do something it wasn't designed to do.
Re: Dominator on the street, power valve or not [Re: galen] #570332
01/03/10 02:39 PM
01/03/10 02:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve been street driving and racing my 8082-3 1050 for years and it has the best manners on the street w/a ft. pv in the 2.5-3.5 range jetted at 82 in the ft. and 90 in the rear. I have street driven it square jetted w/no pv and it was a bit rough down low but came alive when I nailed it.....not much fun and the plugs were hard to keep clean. I now race/drive w/a pv all of the time.
Re: Dominator on the street, power valve or not [Re: Thumperdart] #570333
01/03/10 02:54 PM
01/03/10 02:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah the 8082-2 is a better dom for the street being
that its a 2 circuit carb
Re: Dominator on the street, power valve or not [Re: MR_P_BODY] #570334
01/03/10 03:09 PM
01/03/10 03:09 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Which 2 circuit would you recmmend for the street. I can have mine modified but by the time I buy metering blocks and boosters to try and make the 3 circuit run right, it may just be time to change carbs
