the alternator was also replaced at approximately 4 or 5 years ago. however, a loose tab and faulty factory wiring led to a short issue against the block/head.
car has been re-wired, and i now run all new gauges in custom panel - the voltmeter i installed is working correctly and the battery is not charging - slow steady drop in power.
i'm assuming alternator is the problem, but thought maybe the regulator might be limiting too much - idk if that's possible.
can i test the alternator with a multimeter and what kind of numbers should i be looking for?
