header pipe size #568617
01/01/10 08:55 AM
01/01/10 08:55 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
hi i have ,245 cc intake runner indy 360-1 cnc flow343 @ 700 intake 225 ex @700
,indy intake,950 cfm , 5000 stall t
d 1.6 rollers. 410 cube mopar sb 3550 lbs max rpm 7500 ,12.8 comp
270/277@050 720/670 lift. i have 4 into 1 1 3/4 pipes i was thinking 1 7/8 stepping to 2 inch or straight 1 7/8 and some times 150 shot of gas what do you boys think.
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: header pipe size [Re: Ian] #568618
01/01/10 10:24 AM
01/01/10 10:24 AM
NC
440Jim Offline
440Jim  Offline
NC
I like the stepped pipe idea. But all 1-7/8 would be fine, IMO.
If the car was lighter (2900) and had more CR, I would even consider 2"
Re: header pipe size [Re: 440Jim] #568619
01/01/10 12:59 PM
01/01/10 12:59 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
thanks jim
Re: header pipe size [Re: Ian] #568620
01/01/10 01:28 PM
01/01/10 01:28 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Re: header pipe size [Re: formula S] #568621
01/02/10 11:00 AM
01/02/10 11:00 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
thanks wallace aid 2 inch i think i will run 17/8 stepped to 2 inch into my merge collectors
Re: header pipe size [Re: Ian] #568622
01/02/10 04:46 PM
01/02/10 04:46 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
http://www.maxracesoftware.com/
Ian, do yourself a favour and pick up a copy of Larry Meaux's Pipemax software. It's excellent!
AL....
Alan Jones
Re: header pipe size [Re: LA360] #568623
01/02/10 04:58 PM
01/02/10 04:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
AL....
I got one years ago and alot of dyno test to
see how close it really worked...... I
used it in the exhaust lab for building headers then
would test them on the dyno... then I would make a
set that would deviate from the specs and it would
show either a lesser HP or torque
Re: header pipe size [Re: MR_P_BODY] #568624
01/21/10 11:19 AM
01/21/10 11:19 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
talking to a mate that does mandrel bending he has no dies for 1 7/8 but has 2 inch or 1 3/4 will i get away with 2 inch or not
