Another won't start - 2000 Cherokee 4.0 #568190
12/31/09 08:30 PM
12/31/09 08:30 PM
FL
shupe Offline OP
shupe  Offline OP
FL
2000 Jeep Cherokee, 4.0.
For 3 years it's never missed a beat. Never failed to start, always ran like a top.
Parked it at the house the other night, next
morning it cranks but won't fire.
I removed the air snorkel and sprayed some starting fluid in the throttle body. It would
then *sort* of fire - weekly. Not like a brief
rev up like you usually get with ether. Still,
there was some sort of ignition - very brief,
and never after key was released from the start
position.
There's a "test" schrader valve on the fuel rail.
I pressed it and a little fuel came out under some pressure, but less than I expected.
Any theories?
Re: Another won't start - 2000 Cherokee 4.0 [Re: shupe] #568191
12/31/09 10:44 PM
12/31/09 10:44 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Try banging on the fuel tank while cranking. May have a bad fuel pump.
Re: Another won't start - 2000 Cherokee 4.0 [Re: SALEM1912] #568192
12/31/09 11:08 PM
12/31/09 11:08 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
sounds like a bad fuel pump...check to make sure you got good fuel pressure, with a gauge.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Another won't start - 2000 Cherokee 4.0 [Re: pnypwr] #568193
12/31/09 11:18 PM
12/31/09 11:18 PM
North of the Motor City
DartGTDan Offline
DartGTDan  Offline
If it cranks but won't fire it could also be the cam and/or crank sensor gone goofy. The engine controller needs to "see" where each (cam & crank) are before it will send fuel to the injectors. IIRC the engine will start and run (not optimally) with a missing cam sensor, but needs to "see" the crank for sure to fire.
Hope it helps!
Re: Another won't start - 2000 Cherokee 4.0 [Re: DartGTDan] #568194
12/31/09 11:37 PM
12/31/09 11:37 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Very common for crank shaft sensor.
Re: Another won't start - 2000 Cherokee 4.0 [Re: wheelsup68dart] #568195
01/01/10 06:56 AM
01/01/10 06:56 AM
MA
440beeper Offline
440beeper  Offline
MA
Pretty common issue with the Cherokee 4.0... that would be my bet.
Re: Another won't start - 2000 Cherokee 4.0 [Re: 440beeper] #568196
01/01/10 08:38 AM
01/01/10 08:38 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
That CPS sensor is on the outside back of the Transmission at about the 11 o,clock position where the tranny bolts up to the engine block.
Re: Another won't start - 2000 Cherokee 4.0 [Re: rapom] #568197
01/02/10 02:56 PM
01/02/10 02:56 PM
FL
shupe Offline OP
shupe  Offline OP
FL
I have to say, this board rocks.
Bolted in a new crank position sensor and
she fired right up. Many thanks.
Re: Another won't start - 2000 Cherokee 4.0 [Re: shupe] #568198
01/02/10 09:39 PM
01/02/10 09:39 PM
Columbus, Ohio
Columbus, Ohio
Glad to hear of your success
