Re: FRONT SWAY BAR : Older K-Member/Newer Disc Brakes
[Re: ArchLAB]
#567015
12/30/09 05:49 PM
12/30/09 05:49 PM
Posts: 75,134 A Banana Republic near you.
JohnRR
As for the Caliper Mounting location, I know where you're going w/ that. My answer is that they're on the front. However, I've never had any issues of bump-steer or other geometry problems. Maybe I'd notice a difference if they were on the rear, I dunno. FWIW things work great as they are.
The calipers mounted to the front are the reason you have the problem you do , the original disc setup for a 67-72 A body has the calipers mounted to the rear. the spindles mounted with calipers to the front or the rear will not cause a bump steer issue or any other issues with alignment , that I have ever seen posted .
Looks like you found the simple fix thanks to Jim.
[Re: Stanton]
#567017
12/30/09 07:28 PM
12/30/09 07:28 PM
Posts: 18,686 Fresno, CA
Jim_Lusk
Fresno, CA
I'm not going to get into a pissing match about whether the short links work or not HOWEVER they will create an altogether different problem ...
The torsion bar and LCA have two different pivot points and both have fixed lengths. The problem with the short link is that when the suspension moves through its normal arc of travel the torsion bar and LCA are fighting each other. The torsion bar wants to pull the LCA forward and the LCA will want to pull the torsion bar inward. The long link allows both the torsion bar and the LCA to move in their designed arcs with no interference from each other.
Well, you could at least call the parts by their correct names (it's not a torsion bar, it's a strut rod)......
We've driven many miles (three cars and probably 50,000 miles) and autocrossed with a similar setup without issue. All cars have plenty of suspension travel.
[Re: Jim_Lusk]
#567019
12/30/09 08:35 PM
12/30/09 08:35 PM
Posts: 8,928 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
No, its a swaybar, not a strut rod !
Because of the position and the way the strut rod is mounted at the front, its arc of travel does not affect the LCA's travel. Not so with the swaybar.
Anyhow, its your car, I've made my point.
[Re: Stanton]
#567021
12/31/09 12:27 AM
12/31/09 12:27 AM
Jim_Lusk
Fresno, CA
I've made my point.
Not really.......
[Re: ArchLAB]
#567022
12/31/09 02:34 AM
12/31/09 02:34 AM
Posts: 31,114 Oregon
AndyF
That's why I'm posting. You got any of them solutions for me?
Sure, here you go. 15 inch rotor, 6 piston caliper and this setup goes lock to lock without any interference issues.
[Re: ArchLAB]
#567023
12/31/09 03:20 AM
12/31/09 03:20 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Anyway, maybe I should have these mounted on the rear, but I am trying to remember if my parts actually gave me that option.
You just switch the knuckles from side to side.
AS for the shorter link method, I have done that many times too. Easy, cheap, and works well. No brainer at all. Never seen a negative side effect. The difference int he arc is minimal, and it's still all held together with rubber, so there is give.
[Re: AndyF]
#567024
12/31/09 03:22 AM
12/31/09 03:22 AM
dave571
....Sure, here you go. 15 inch rotor, 6 piston caliper and this setup goes lock to lock without any interference issues.
Nice pic Andy. What size wheel does this require?
