Page 2 of 3 1 2 3
Re: Racing with A518 -46RH transmission [Re: Jeepmon] #56642
04/19/08 02:44 PM
04/19/08 02:44 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Do I detect just a hint of sarcasm?
I do believe if someone took a stock computer controlled 46RE that was shifting at 4500 rpm, or when it felt like it (as they seem to do) and swapped in a built 727 with a manual valve body, the results would be surprising.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Racing with A518 -46RH transmission [Re: Adobedude] #56643
04/19/08 05:15 PM
04/19/08 05:15 PM
If the shift rpm is all that's holding you back I wouldn't be giving all the credit to a 727 if you shifted it higher and went quicker. Why can't you shift your 46RE manually if you need higher shift points?
As for the 1 1/2 second claims by SMR....I've dealt with SMR in the past. In my (lengthy and very expensive) experience, there is certainly no lack of BS from that operation!
Re: Racing with A518 -46RH transmission #56644
04/19/08 06:01 PM
04/19/08 06:01 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I never said my 46RE was stock, and I never said it was holding me back.
I said...I'm going with a 727 because it's lighter and a three speed. I don't need/use/want an OD so why tow one down the 1/4 mile.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Racing with A518 -46RH transmission [Re: Adobedude] #56645
04/19/08 06:14 PM
04/19/08 06:14 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I wish you'd hurry up and verify the performance gain!
(1) Because I know you really want it for yourself.
(2) Because it would help me talk myself into doing the swap right now... while it's relatively "easy"... without the engine, headers and exhaust system getting in the way.
Re: Racing with A518 -46RH transmission [Re: Duner] #56646
04/19/08 07:36 PM
04/19/08 07:36 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Me too...
Being that I don't have a transmission right now.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Racing with A518 -46RH transmission [Re: Adobedude] #56647
04/19/08 08:35 PM
04/19/08 08:35 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Nope.. no sarcasm... I REALLY want to know if there is a drastic difference... I'm looking for an OD unit to run in my car and if the performance is down a full second.. Then I'd probably stay away from the 500/518
Re: Racing with A518 -46RH transmission [Re: Jeepmon] #56648
04/19/08 10:15 PM
04/19/08 10:15 PM
Concord California
E
Evil_Ways Offline
Evil_Ways  Offline
E
Concord California
Me too.
Re: Racing with A518 -46RH transmission [Re: Evil_Ways] #56649
04/26/08 07:00 PM
04/26/08 07:00 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
bump... any update yet?
Re: Racing with A518 -46RH transmission [Re: Jeepmon] #56650
04/26/08 08:08 PM
04/26/08 08:08 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Still waiting on my CRT tranmission, John's having back problems, so his time to build transmissions is limited. Having been there myself, he can take all the time he wants.
One thing I might point out...I'm breaking the golden rule of "one mod at a time". When I hit the track again, it will be with a Detroit Locker (replacing my toasted peg leg Auburn LSD), Monoleafs and Caltracs...A 3800-4000 stall converter (was 2800), and a new tune on my PCM.
That and no AC/Heater....The list goes on.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Racing with A518 -46RH transmission [Re: Adobedude] #56651
04/26/08 08:46 PM
04/26/08 08:46 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Well, so much for the trans vs. trans test...
Re: Racing with A518 -46RH transmission [Re: cudadoug] #56652
04/27/08 09:35 AM
04/27/08 09:35 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I know, I figured since it was apart, why not do everything else.
Even got my headers re-coated, that alone HAS got to be good for a tenth.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Racing with A518 -46RH transmission [Re: cudadoug] #56653
01/05/10 10:48 AM
01/05/10 10:48 AM
Bowling Green, Ky
TheDodgeBoys Offline
Bowling Green, Ky
I dont know about overall E.T, but the A518 will give you a better 60 foot time due to the lower gear ratio in the planetary gear set! I think the A518 has a 2.74 low gear where the 727 is either a 2.45 or 2.54...cant remember!
1968 NSS/AA "HEMI" DODGE DART 1970 "452" E-85 PLYMOUTH DUSTER 1987 "318" RAM D100 1983 "318" RAMCHARGER (408 SOON) RACER'S FOR CHRIST CHAPLAIN NHRA DIVISION 3 "LAND OF THE WINNERS" ....AND ON THE 8TH DAY, GOD CREATED MOPARS
Re: Racing with A518 -46RH transmission [Re: Adobedude] #56654
01/05/10 11:22 AM
01/05/10 11:22 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Why not just run a well built 904? I run a 727 in my Dart because it's what I had. If I were doing it again it would be a 904.
Re: Racing with A518 -46RH transmission [Re: Adobedude] #56655
01/05/10 01:01 PM
01/05/10 01:01 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Wow this thread came back from the dead.
518's do not have 2.77 1st gear ratios. They have 2.45 just like a 727.
Re: Racing with A518 -46RH transmission [Re: YbNoRmAL] #56656
01/05/10 02:28 PM
01/05/10 02:28 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I can't tell you any ET gain or loss, but I just wanted to say that Griner makes a fully manual valvebody for the 500/518s. You actually make the 3rd to OD shift with the shifter.
This is exactly what I want.
It eludes me as to how you would be able to shift into overdrive with a shifter though. Overdrive is activated with a solenoid. Is it a button on the shifter?
As far as I know, the only way to do this and still have overdrive and lockup is with vac/pressure switches.
Details???
Re: Racing with A518 -46RH transmission [Re: POS Dakota] #56657
01/05/10 02:37 PM
01/05/10 02:37 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Details???
Maybe it's a custom made valve body and not a modified stock one ?
And where are the apples to oranges result of the swap ???
Re: Racing with A518 -46RH transmission [Re: TheDodgeBoys] #56658
01/05/10 02:45 PM
01/05/10 02:45 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Old thread....
With the 727 and 4K converter I picked up 5 tenths on my 60 foot times...I easily picked up 8 tenths on my 1/4 mile times, but I was falling flat on my nose. Now with a better cam designed for my heads, a 4bbl M1 and 58mm TB, it's running high 12's, was runnning low 14's to 13.8.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Racing with A518 -46RH transmission [Re: Adobedude] #56659
01/05/10 02:49 PM
01/05/10 02:49 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Old thread....
With the 727 and 4K converter I picked up 5 tenths on my 60 foot times...I easily picked up 8 tenths on my 1/4 mile times, but I was falling flat on my nose. Now with a better cam designed for my heads, a 4bbl M1 and 58mm TB, it's running high 12's, was running low 14's to 13.8.
Was that 5 tenths along with other changes? How much do you think the Caltracs played into that pick up on your 60 ft?
I can see where there is a lot of rotating mass removed , the power goes straight thru the OD section but it does spin all that weight and the slight drag of the OD clutches .
Re: Racing with A518 -46RH transmission [Re: Adobedude] #56660
01/05/10 02:59 PM
01/05/10 02:59 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Old thread....
That was well worth the wait.. Thanks for sharing the results..
Re: Racing with A518 -46RH transmission [Re: JohnRR] #56661
01/05/10 03:22 PM
01/05/10 03:22 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Old thread....
I'd say the 5 tenths was due to the 4k converter and 727. I wish I would have run it a few times with out the Monos and Caltracs. But I never spun with the built 46RE and 2800 converter, so I can't say I picked up any in the traction department.
But....trying to make ths clear, I bet the 727 & 4K stall would have taxed the non monoleaf/caltrac set up I ran with the 46RE.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Page 2 of 3 1 2 3
