Page 3 of 7 1 2 3 4 5 6 7
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566231
01/01/10 07:23 PM
01/01/10 07:23 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
pass
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566232
01/01/10 07:31 PM
01/01/10 07:31 PM
USA
I
indy dart Offline OP
I
USA
The spotlight in the grille looks factory installed when viewed up-close. There is an emblem on the dash that reads "When reaching speeds in excess of 120 MPH windows must be rolled up". It has been an exciting piece for sure. Just wish it could tell stories.
1970 B5 v-code Superbird
1971 Dodge Charger R/T in GA4
Re: 1966 hemi coronet decoder [Re: indy dart] #566233
01/01/10 07:34 PM
01/01/10 07:34 PM
Any interior pics?
Were the A-100 style seats factory installed as well?
Re: 1966 hemi coronet decoder #566234
01/01/10 07:37 PM
01/01/10 07:37 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The seats are similar to A100 seats but after a look don't appear to be, and no, they were not factory installed, car originally had a bench seat (as all sedans did).
Cleanly installed yes, but it's not factory
Re: 1966 hemi coronet decoder #566235
01/01/10 07:39 PM
01/01/10 07:39 PM
USA
I
I
USA
Myself, I dont have the interior pics. The car is close by and I will visit next week. I will get some pics. I assume the seats were installed afterward as the vinyl does not match. Scott knows the particulars better than I do.
Re: 1966 hemi coronet decoder [Re: indy dart] #566236
01/01/10 08:41 PM
01/01/10 08:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's an interior shot, no beauty queen but if it were me I'd clean it, detail it, get the wiring squared away and leave it "as is" without a re-do in an effort to keep it original to "Day 2"
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566237
01/01/10 08:47 PM
01/01/10 08:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's what the front seat used to look like
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566238
01/01/10 11:06 PM
01/01/10 11:06 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
after seeing the pics I am very curious as to what the cost was, I have never seen a Hemi in a garage or in a barn and I have no idea what something like this would cost to buy!
71 GTX 4sp Dana GY9 HD Road King
Re: 1966 hemi coronet decoder [Re: AZ-Nick] #566239
01/01/10 11:12 PM
01/01/10 11:12 PM
USA
I
I
USA
Nice interior pics Scott. Thats a homemade trans tunnel to accomodate the shifter. I assume it has line-lock.
Re: 1966 hemi coronet decoder [Re: indy dart] #566240
01/01/10 11:22 PM
01/01/10 11:22 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes it has a line lock, interior looks ratty but Like I said, it will likely clean up to look a TON better with a good detail job. I think I figured out why the swap to buckets was made (haven't quite figured out what car those are out of?) the shifter style shown locates the shifter further back than the stock position (likely hitting the bench seat) it requires a rearward notch to be cut in the factory floor hump to install it, also why they likely built the aluminum enclosure for the shifter box.
Also, with the amount of dirt on that interior I can only guess it sat for a fair amount of time with the windows rolled down? I'd be checking the floor for moisture damage, hopefully it never got wet inside, if the carpet ever got wet it will likely be needing floor pans, and that would suck on such an otherwise dry car.
Re: 1966 hemi coronet decoder [Re: indy dart] #566241
01/01/10 11:31 PM
01/01/10 11:31 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Here is another one to make you sick,6000mi
Re: 1966 hemi coronet decoder [Re: 62maxwgn] #566242
01/01/10 11:35 PM
01/01/10 11:35 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
It's real.
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566243
01/01/10 11:51 PM
01/01/10 11:51 PM
California
mickm Offline
mickm  Offline
California
but how do you "clean up" something like that? it seems like it would just be opening up a can of worms. everything would need to be taken off or apart to really clean, then just exposing the mess beneath it, ad infinitum!
i like the idea of day 2, but in a case like this, it seems like cleaning it would be difficult, and almost as much work as restoring it!
Re: 1966 hemi coronet decoder [Re: 62maxwgn] #566244
01/02/10 12:00 AM
01/02/10 12:00 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Some or most of the interior would need to be at least removed to get it back up to snuff, but a careful removal, thorough cleaning, and reinstallation would be no big deal, just a bunch of hours, I've taken on much worse.
Re: 1966 hemi coronet decoder [Re: 62maxwgn] #566245
01/02/10 12:01 AM
01/02/10 12:01 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
62mxwgn,
WOW! That is a shame, what's the deal with that one? What trans?
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566246
01/02/10 08:26 AM
01/02/10 08:26 AM
the house on the left.
cogen80 Offline
cogen80  Offline
cool car. some better pictures would have been nice though. those suck.
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566247
01/02/10 09:57 AM
01/02/10 09:57 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
62mxwgn,
Scott,that car has not moved since 1969.Original motor is chicken coop on homeade engine stand,locked up for years.Was raced for two years then taken apart to make streetable,thats as far as it went.Transmission is original with old Fairbanks deep pan.Flex plate mounting lugs are completely rusted off converter.Been trying to buy since 1980,it will sit and rot.Owner could care less about the car or money.One of 19 Deluxe 2dr auto sedans.
Re: 1966 hemi coronet decoder [Re: 62maxwgn] #566248
01/02/10 10:18 AM
01/02/10 10:18 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Request permission to faint now, sir....
Re: 1966 hemi coronet decoder [Re: 62maxwgn] #566249
01/02/10 10:38 AM
01/02/10 10:38 AM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
62mxwgn,
Bill - you are killing me with that picture.....
Re: 1966 hemi coronet decoder [Re: 62maxwgn] #566250
01/02/10 11:06 AM
01/02/10 11:06 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I can never understand why people that own cars like that won't come off of them? Must be some kind of mental disorder because it is sure seems to be common. The car that's on the rotiserie in primer in my earlier posts on this thread is another one of the 19 you mentioned, it was light blue metallic with a blue interior, it's from Concord California, I've known the car since about 1985.
