Page 1 of 7 1 2 3 4 5 6 7
1966 hemi coronet decoder #566191
12/29/09 09:01 PM
12/29/09 09:01 PM
USA
I
indy dart Offline OP
I
USA
I'm going to look at a hemi coronet in a couple of days. The guy says it has a buildsheet and the original engine. I have no idea how to decode a VIN or buildsheet. Can anyone help out? Thanks
1970 B5 v-code Superbird
1971 Dodge Charger R/T in GA4
Re: 1966 hemi coronet decoder [Re: indy dart] #566192
12/29/09 09:04 PM
12/29/09 09:04 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If it's a 1966 Hemi car the fifth digit in the VIN will be an H. Of course that's if that VIN Tag actually came on that particular car. The engine did not have VIN number stampings that year but they did have particular assembly date info that should link to the cars build date, takes a decent education to figure out what is correct. Re-body and fake Hemi cars (and fake fender tags & Broadcast Sheets) are common these days, you can't take anything at face value anymore. It sounds like you should obtain some expert to take with you for help if you plan on making a good on the spot buying decision.
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566193
12/29/09 09:32 PM
12/29/09 09:32 PM
USA
I
I
USA
You're right, I have already contacted an expert to go along.
Re: 1966 hemi coronet decoder [Re: indy dart] #566194
12/29/09 10:49 PM
12/29/09 10:49 PM
Wpg, Mb, Canada
six-barrel Offline
six-barrel  Offline
Wpg, Mb, Canada
I'm not sure on 66 but for 67 (I believe 66 and 67 are the same).
Look on the inside of the upper rad support, there should be a stamping of the sequence number. The same number is also stamped on the driver side rear bumper support (or somewhere around there).
Anyway this number is the sequence "build" number not the vin.
You need the broadcast sheet that has the the vin and the sequence number to confirm the body sequence matches. Also make sure the vin tag rivets are the rosette style.
Without the broadcast sheet it's pretty hard to confirm the body sequence and vin number. It's buyer beware.
The body should have reinforced spring perches as well as a couple of there "Hemi" modifications.
The more original documentation the seller has the better, good luck.
Re: 1966 hemi coronet decoder [Re: six-barrel] #566195
12/29/09 11:05 PM
12/29/09 11:05 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
You are on the right track but not quite hitting the bullseye's.
66 and 67 were different (5th VIN digit was an H for Hemi engine in 66, the fith VIN digit was a J for Hemi in 1967)
The SO number is stamped on the drivers side radiator core support and USUALLY on the drivers side rear panel behind and below the rear bumper, this same number is found on the fender tag and the Broadcast Sheet. The VIN number is not found on the fender tag, only on the Broadcast sheet. Both the VIN and SPD are also found on the factory Certicard should the owner have a copy.
The only unibody body "Hemi" modifications include forward leaf spring Torque boxes, reinforcement plates within the Torque boxes, rear leaf spring hanger reinforcement plates, and a pinion snubber plate on the floor above the pinion snubber. Not every Hemi car recieved these weld on additions (although all SHOULD have) the lack of them does not dethrone it as a Hemi car, but it would lead to some serious questioning as it's quite rare for them to be lacking.
The Hemi K-Member is unique and has a skid plate.
All 4 speed cars had Dana 60 rear ends, all automatic cars had 8.75 rear ends.
Factory wheels were all the same, 14 x 5.5 steel wheels (look for a "5" stamped on both sides of the valve stem hole) with either full wheel covers or dog dish style hub caps
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566196
12/30/09 01:28 AM
12/30/09 01:28 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Both the VIN and SO number are also found on the factory Certicard should the owner have a copy.
VIN yes. I thought the SPD is there but not the remainder of the SO.
The VIN number is only found on the fender tag....
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 1966 hemi coronet decoder [Re: 69CoronetRT] #566197
12/30/09 01:46 AM
12/30/09 01:46 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
RT you are correct on both, mixed my terms while typing, thanks for catching that. I also forgot to mention the Certicard, a 66 car would have come with one located in a black plastic pouch attached to the back side of the drivers side radiator core support, if it's there and original it will have the VIN# and some of the info shown on the fender tag as well.
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566198
12/30/09 02:24 AM
12/30/09 02:24 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Fender tag - Same car
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566199
12/30/09 02:25 AM
12/30/09 02:25 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
VIN tag, different car, rivots are correct
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566200
12/30/09 02:26 AM
12/30/09 02:26 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
SO stamping location in rear
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566201
12/30/09 02:27 AM
12/30/09 02:27 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Core support stamp area
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566202
12/30/09 02:28 AM
12/30/09 02:28 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
All 66 Hemi's had a unique bracket shown here (black bracket and all else shown attached to it). It was unique to Hemi's only, one year only.
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566203
12/30/09 02:31 AM
12/30/09 02:31 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The rear leaf spring eye support plates - Hemi only parts, not even convertibles got these unless they were Hemi convertibles
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566204
12/30/09 02:36 AM
12/30/09 02:36 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Forward Leaf Spring Torque Boxes (area sprayed with white primer)
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566205
12/30/09 07:28 AM
12/30/09 07:28 AM
USA
I
I
USA
Good info guys. The car is supposed to have the broadcast sheet. The car is said to be a lo-mile survivor. I have been on my share of wild-goose chases so I am cautious. I appreciate the info and if it pans out I will get pics.
Re: 1966 hemi coronet decoder [Re: indy dart] #566206
12/30/09 10:31 AM
12/30/09 10:31 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Again, just be aware that there are reproductions of everything these days, fender tags, VIN tags, window stockers, certicards, engine stampings, body stampings, torque boxes, and yes, even broadcast sheets (artifically aged looking and all!) anything that identifies a car as a "real" hemi is available now, you can't take anything at face value these days!
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566207
12/30/09 01:27 PM
12/30/09 01:27 PM
USA
I
I
USA
We have looked at the car. It is without a doubt the real deal. It is a 12000 mile police captain's car. It has many unique features. I wish someone would call me to help verify a few things. 417-327-5869 It has the vin wl21h. It is a very exciting find.
Re: 1966 hemi coronet decoder [Re: indy dart] #566208
12/30/09 01:28 PM
12/30/09 01:28 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I sent you my phone number
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566209
12/30/09 02:48 PM
12/30/09 02:48 PM
Horsham, Pa.
Finoke Online content
Finoke  Online Content
Horsham, Pa.
I can email you pictures of a real 66 Hemi Coronet broadcast sheet if you want.
PM me your email address.
Tom
Re: 1966 hemi coronet decoder [Re: ScottSmith_Harms] #566210
12/30/09 02:56 PM
12/30/09 02:56 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Try to find as much History about the car as you can from this owner. Things like previous owners, were this owner bought the car from. Low mile cars usually have a Race History, not all but a lot. This History is good both before and after purchases. Maybe it is a real Hemi car and its missing a Distributor and you could phone previous owners and ask them were missing parts could be and also you could get old pictures and history from them.
Nothing like an old show box Hemi car.
1971 HEMI E BODY REGISTRY
