Re: Dyno Results
[Re: 71ChallengerSE]
#566171
12/29/09 09:12 PM
12/29/09 09:12 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
does a blown engine count? my video is in my signature.i will get the printout. this is a stock block 1968 440[.030 over]446,factory iron heads ported[2.14/1.81 valves]280/180 cfm at .600 lift blower roller cam .646/.631 lift[1.5 aluminum roller rockers] 291/306 at .020 duration 112 lobe seperation. eagle rods,wiseco 8.5cr blower piston,hellfire rings,aftermarket crank stock stroke.stock main caps,main studs/girdle 3/8,windage tray,milodon single line swinging pickup,melling HV pump,blowershop teflon stripped 8-71[10% OD]12 lbs of boost 2x850 holley carbs on race gas thru a A/W intercooler.
Re: Dyno Results
[Re: blownzoom440]
#566172
12/29/09 09:16 PM
12/29/09 09:16 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I'll do ya one better. I'll photo copy all my dyno sheets from my dyno session, shows HP, tq, lbs fuel per hour, etc. measured in 100 rpm increments.
I'd have to snail mail them to you though.
or I could fax them if you've got access to a fax machine
**Photobucket sucks**
Re: Dyno Results
[Re: 70Cuda383]
#566174
12/29/09 09:30 PM
12/29/09 09:30 PM
70Cuda383
Marysville, O-H-I-O
and as far as "stock 383 specs" what do you need? hp/tq only?
depends on which year and variant, but I think most of the 2bbl 383s were 290-ish HP, and the 4bbls were around 330-335Hp. I don't remember the torque numbers off the top of my head though.
EDIT: DOH! that's what happens when your posting at work, something comes up that needs your attention when you're in mid-post, you comeback, finish your post, and find out that someone already beat you to it by 10 minutes!
Re: Dyno Results
[Re: patrick]
#566176
12/30/09 10:56 AM
12/30/09 10:56 AM
Posts: 3,441 Mo.
supercomp
Mo.
400 block 4.375 bore 4.150 stroke. 500 c.i. Pistons are JE flat tops 1.365 c.h., Rods are Manley H beams 6.535 long. Callies crankshaft 4.150 stroke. Heads are B1 originals. Jesel indivigual shaft rockers, PSI valve springs, 2.300 in 1.78 ex valves. 62 cc combustion chambers, 13.5 compression. B1 intake with 1050 dominator on gas.. Cam is 311 / 314 @ .020 280 / 283 @ .050, .772 / .759 lift with 1.7 in 1.65 ex rockers.
Re: Dyno Results
[Re: blownzoom440]
#566178
12/30/09 11:07 PM
12/30/09 11:07 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I hope this helps
Here's the motor info....
440, .030 over cast crank 6LY rods hyper pistons sitting .070 in the hole CR is 8.6 to 1
OOTB Eddy heads (Intake Valve Diameter (in) 2.140 in. Exhaust Valve Diameter (in) 1.810 in.)
Cam, (solid lift) Intake Valve Lift with 1.5 Ratio 0.555 in. Exhaust Valve Lift with 1.5 Ratio 0.555 in. Duration at 050 inch Lift 262 int./262 exh. Did NOT degree it in just lined up the dots but.. Lobe Separation (degrees) 110 Intake Centerline: 106
Team G intake
750 BG claw (running 110 oct)
MSD dist locked out @ 38*s
2 1/8 hooker SC headers.
The dyno results
