UCA Inspection covers ?? #566120
12/29/09 08:25 PM
12/29/09 08:25 PM
Retired now in Tennessee
Chi_Town_Runner Offline OP
My description for lack of a better term. On my '68 RR there are two openings in each inner fender to access the upper control arm adjustment bolts. The forward ones are sheet metal and screwed into the fender (I have those). The two rear ones (I only have one in place on the passenger side) are some type of stiff cardboard type of material held in place by spring pins (another one of my descriptions).
Does anyone know if they repro those rear inspection covers?
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: UCA Inspection covers ?? [Re: Chi_Town_Runner] #566121
12/29/09 08:28 PM
12/29/09 08:28 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
they are used to access the cam bolts durring alignment.
I know the rubber ones with the clips are repoped, I assume most repo shops have them. There is also a metal one not sure if it repoped or not.
Oh, this is for an e-body but I assume b body is the same
Re: UCA Inspection covers ?? [Re: 6T6Cuda] #566122
12/29/09 08:33 PM
12/29/09 08:33 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Right, the rears are rubber, using wire spring-clips to attch them. The fronts are metal, with hex-head screws attaching them.
I think all 4 are being reproduced; one of those things one sees in an ad somewhere, but doesn't remember later whose ad it was...might have been in MCG.
Re: UCA Inspection covers ?? [Re: topside] #566123
12/29/09 08:58 PM
12/29/09 08:58 PM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
AMD makes them (fronts)
Re: UCA Inspection covers ?? [Re: TrueTripleX] #566124
12/29/09 09:11 PM
12/29/09 09:11 PM
Yes the front ones are metal. I have those.
It's the rear ones I'm in need of.
Anyone else with a possible source?
Frank
Re: UCA Inspection covers ?? [Re: Chi_Town_Runner] #566125
12/29/09 10:09 PM
12/29/09 10:09 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
They are made of emasticated rubber( I hope I spelled that right)
Dantes got em
http://www.dantesparts.com/splashshields.html
Looks like Jims got em as well
http://cgi.ebay.com/ebaymotors/DMT-66-70...=item53dd5979a3
Re: UCA Inspection covers ?? [Re: gtx6970] #566126
12/29/09 10:40 PM
12/29/09 10:40 PM
Bill,
Thanks a lot.
I figured if any one would know, you would.
BTW, I once went out with a girl that tried to do that to me.
I really appreciate the info.
I just ordered them from Jim at DMT. A real claass act and all around good guy.
Frank
Re: UCA Inspection covers ?? [Re: Chi_Town_Runner] #566127
12/29/09 11:58 PM
12/29/09 11:58 PM
I made my own and duplicated the original (hard and dried up) rubber ones. Turned out perfectly.....and a lot cheaper than the pricing listed above!
