will spring relocation change shock length____??? #565766
12/29/09 12:31 PM
12/29/09 12:31 PM
Los Angeles
DusterDavis Offline OP
Los Angeles
I am about to relocate/custom arc my leaf springs on my 73 Duster to fit big 275/60 tires.
Will I have to go with longer shocks(air shocks)? or can I go with stock length shocks(KYB gas adjust)??
Thanx for any help!
Re: will spring relocation change shock length____??? [Re: DusterDavis] #565767
12/29/09 01:33 PM
12/29/09 01:33 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Relocating them inward would require a slightly shorter shock, not enough to mean anything. If you rearch the springs though, that could require a longer shock. After you do the work I would let the rearend droop on the springs and measure your shock free length to see what you need.
I used to see lots of upper shock mounts ripped out of 4 speed cars even with stock rear suspension. It was from powershifting and dropping the clutch but it shows what can happen with shocks that are too short.
Sheldon
Re: will spring relocation change shock length____??? [Re: RUNCHARGER] #565768
12/29/09 04:48 PM
12/29/09 04:48 PM
Here
jcc Offline
jcc  Offline
Here
, but OP forget KYB's
"When one’s appeal is emotional, it does not matter if there is no substance."
Re: will spring relocation change shock length____??? [Re: RUNCHARGER] #565769
12/29/09 05:32 PM
12/29/09 05:32 PM
fresno ca
mikeysmopars Offline
fresno ca
AH HA! Thats why my 69 4 speed gtx looks like a bomb went off in my shock area!!!
Founder and CEO of the Central Valley Mopar Drag Pack
