440 Source Heads - Which Spark Plugs? #565713
12/29/09 10:59 AM
12/29/09 10:59 AM
Greer, SC
TooMany62s Offline OP
Greer, SC
I'm using 440 Source aluminum heads on a 10.5:1 mild street motor. A&A max wedge intake. Which spark plugs do I need? Prefer Champion but will use what I can find. Thanks.
Re: 440 Source Heads - Which Spark Plugs? [Re: TooMany62s] #565714
12/29/09 11:04 AM
12/29/09 11:04 AM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
Champion RJ12YC If I remember correctly or call Kim at 440 Source 661-951-3700 I converted it to an Autolite plug but needed to go 1 heat range hotter for my setup.
Re: 440 Source Heads - Which Spark Plugs? [Re: Boise Chall] #565715
12/29/09 11:15 AM
12/29/09 11:15 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I think I used plugs for a 90's magnum v8? I can't remember now, I just remember 440source gave me the plug number and I bought the autolite equivalent.
Re: 440 Source Heads - Which Spark Plugs? [Re: DaytonaTurbo] #565716
12/30/09 07:26 AM
12/30/09 07:26 AM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
I used small block plugs, they have the extra reach.
Re: 440 Source Heads - Which Spark Plugs? [Re: 1fastrunner] #565717
01/04/10 11:31 AM
01/04/10 11:31 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
Does anyone know if Brandon (440 Source) is still a member here? I tried to figure out his user name but couldn't remember it. The search function is not turning up anything either.
-Dave
Re: 440 Source Heads - Which Spark Plugs? [Re: GTSDave] #565718
01/04/10 12:24 PM
01/04/10 12:24 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have the number for NGKs somewhere.I have Autolites in mine now.Going to try the NGKs as everyone that uses them say they are great.My 440 has 12.5 compression with the Stealths.Rocky
Chrysler Firepower
Re: 440 Source Heads - Which Spark Plugs? [Re: GTSDave] #565719
01/04/10 12:51 PM
01/04/10 12:51 PM
Manitoba, Canada
Manitoba, Canada
-Dave
I think his username is 440sourcedotcom but I don't think he posts much anymore because of all the bashing.
