Re: TPS installation questions
[Re: Kelob_pie]
#565148
12/29/09 06:03 PM
12/29/09 06:03 PM
Posts: 2,255 IL
furious70
IL
Don't know specifically on that one, but often times there is enough slop in the bolt holes to allow a small amount of adjustment. Yours would appear to be reading high, causing high upshifts, so you could try loosening it, then rotating it the same direction as the throttle shaft rotates, hold it tight, and then tighten the bolts and go drive to see if that made any difference.
Any chance you inadvertently messed up the kick down while you were in there?
70 Sport Fury 68 Charger 69 Coronet 72 RR
