Re: Jetting for 414 stroker
[Re: Mr.Yuck]
#564876
12/28/09 02:36 PM
12/28/09 02:36 PM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
I'm guessing you mean 78-84. I'd try that for starters. Probably could use 31 squirters, and a 6-6.5 PV.
good start point,depends on temp and elev also....
[Re: 64physhy]
#564883
12/28/09 03:34 PM
12/28/09 03:34 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I just found the spec sheet on it online. Comes with 74/84 jets. The guy I bought it from said it had 78/84, so either he was wrong, or the primary jet was changed. The squirters (original) are #31. I guess I'll try it as-is.
you go back to stock (check to see they have not monkeyed with high speed air bleeds) the work from there
[Re: AndyF]
#564887
12/28/09 04:25 PM
12/28/09 04:25 PM
Posts: 15,493 the boonies
aarcuda
the boonies
thats because the engine pulls in air and that air brings gas along with it dependent on the venturies, metering orifaces and so forth. a bigger engine may need more gas when its running at higher power levels but the valving in the carb will still put the same gas to air ratio and if anything, would just slow the engine down somewhat as the bigger motor needs more fuel which the smaller carb might not be able to supply. the only tweaking would be minor adjustments for idle due to vacuum differences and wot if the carb is too small
jetting should be individualized for max power on any engine. internet suggestions should be starting points and not gospel cause you wont have the same intake system from aircleaner, carbs, manifold to heads
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
