magnum block questions #564177
12/27/09 04:56 PM
12/27/09 04:56 PM
detroit, mi
POS Dakota Offline OP
detroit, mi
Running a 408, what are you guys doing to the bottom end so they live? Are just the stock caps and bolts enough for around 500 hp?
Block filling...is it necessary and how tall of a fill? to what point?
Studs/girdle???
I am not planning on turning this motor over 6000 rpm and I am not using nitrous.
This is an all forged rotating assembly I am using.
Thoughts?
Re: magnum block questions [Re: POS Dakota] #564178
12/27/09 05:27 PM
12/27/09 05:27 PM
swamps of florida
beepsalot Offline
beepsalot  Offline
swamps of florida
main cap studs. everything else ought to be okay
Just Follow Me Down the Street, You'll Know i'm Up to No Good...
