Car won't start #563929
12/27/09 01:24 PM
12/27/09 01:24 PM
San Gabriel, CA 91775
rexus31 Offline OP
rexus31  Offline OP
1965 Chrysler 300. The motor (383, 4V) turns over but it won't fire. It doesn't even act like it wants to fire; it just turns over. The car is stock except for a Pertronix Flame Thrower II ignition and coil. Ballast is bypassed per Pertronix instructions. New wiring harnesses. I have not had an issue with the motor firing other than a bad coil a couple months ago. I swapped the coil this morning with one I know works and that didn't resolve the issue. I've got 12V in Run and Start. Any ideas?
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: Car won't start [Re: rexus31] #563930
12/27/09 01:27 PM
12/27/09 01:27 PM
Clarksville, Tennessee
monoptn Offline
mopar addict
monoptn  Offline
mopar addict
It ain't got no gas in it.......
Re: Car won't start [Re: monoptn] #563931
12/27/09 01:31 PM
12/27/09 01:31 PM
rexus31 Offline OP
rexus31  Offline OP
It's got gas.
Re: Car won't start [Re: rexus31] #563932
12/27/09 01:35 PM
12/27/09 01:35 PM
monoptn Offline
mopar addict
monoptn  Offline
mopar addict
Lol, just kidding. But when I read your question, I heard Billy Bob Thornton say "It ain't got no gas in it."
Re: Car won't start [Re: monoptn] #563933
12/27/09 01:52 PM
12/27/09 01:52 PM
Sue Offline
Sue  Offline
dist pickup
Re: Car won't start [Re: Sue] #563934
12/27/09 01:54 PM
12/27/09 01:54 PM
rexus31 Offline OP
rexus31  Offline OP
Any way to test that?
Re: Car won't start [Re: rexus31] #563935
12/27/09 04:31 PM
12/27/09 04:31 PM
Any ideas?
With your VOM, unhook the 2 dist pickup leads & see if it has basic continuity and then see if the dist pickup generates a signal on these same 2 leads when you crank it (not sure which scale (milli volts?)
Re: Car won't start [Re: RapidRobert] #563936
12/27/09 11:13 PM
12/27/09 11:13 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Don't know much about the pertronix stuff...put the points back in and try that..
Re: Car won't start [Re: AARCONV] #563937
12/28/09 01:37 AM
12/28/09 01:37 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Have you verified basics like you aren't getting any spark or are we just jumping to that conclusion because the car won't fire up?
Re: Car won't start [Re: rss] #563938
12/28/09 01:57 AM
12/28/09 01:57 AM
Los Angeles
Hazwoy Offline
Hazwoy  Offline
Los Angeles
Here is a great link to help you-
http://www.moparaction.com/Tech/archive/roadside.html
Look at "Cranks, But Won't Start"
Re: Car won't start [Re: Hazwoy] #563939
12/28/09 08:04 PM
12/28/09 08:04 PM
rexus31 Offline OP
rexus31  Offline OP
Thanks. I've got voltage to the coil in both the Run and Start Position but no spark from the coil. Being as I have already attempted to swap the coil with a known good one, I don't think the coil is the culprit. I think the Pertronix unit failed. I removed the Pertronix unit and sent it back to Summit for a replacement as it was still under warranty. I think I'm going back to the points and will shelf the Pertronix as a back up. The funny thing is, I've run the pertronix on my '64 GTO for 5 years with no issues. I will install the points, stock coil and ballast and report back.
Re: Car won't start [Re: rexus31] #563940
12/29/09 03:01 AM
12/29/09 03:01 AM
Los Angeles
Hazwoy Offline
Hazwoy  Offline
Los Angeles
The Pertronix is an awesome system. Pretty much the first mod I will do on a car. I did have a 1962 Chrysler with a 361. Had Pertronix in it and then started having running/starting problems several years later. Car had 120k miles on it , I replaced original distributor with a new Mallory distributor. It was long ago but I am pretty sure the distributor bushings were worn out on the original so no way the Pertronix could keep it firing with shaft wobble. Try another distributor maybe if your miles are up there
Re: Car won't start [Re: Hazwoy] #563941
12/29/09 12:07 PM
12/29/09 12:07 PM
rexus31 Offline OP
rexus31  Offline OP
The distributor is new.
Re: Car won't start [Re: rexus31] #563942
12/29/09 06:59 PM
12/29/09 06:59 PM
Los Angeles
Hazwoy Offline
Hazwoy  Offline
Los Angeles
Let us know what happens with the points or new Pertronix.
Re: Car won't start [Re: Hazwoy] #563943
12/31/09 04:49 PM
12/31/09 04:49 PM
rexus31 Offline OP
rexus31  Offline OP
The Pertronix was the culprit. I put the points back in along with the stock coil and ballast and it fired right up.
Re: Car won't start [Re: rexus31] #563944
12/31/09 07:32 PM
12/31/09 07:32 PM
rexus31 Offline OP
rexus31  Offline OP
Well I just got back from a cruise and the timing is jumping all over the place. I think I have a faulty distributor which may have shorted out the Pertronix unit. I set the timing to 10* BTDC and went for a short cruise. The car started running like it was on 4 cylinders. When I checked the timing it was 5*ATDC. I adjusted the timing to 10* BTDC and went for another ride. This time it jumped to 15* BTDC. I'll be installing a new distributor Saturday. I hope it's a bad distributor and not a bad balancer. My machinist said the balancer looked real good when the motor was rebuilt about 500 miles ago. We'll see.
Re: Car won't start [Re: rexus31] #563945
12/31/09 07:53 PM
12/31/09 07:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Balencer wouldn't cause the timing to jump around and make the engine run bad. It would just be off when you set it and stay there.
Re: Car won't start [Re: rexus31] #563946
12/31/09 07:55 PM
12/31/09 07:55 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Aside from the distributor, you might check for timing chain slop...
Re: Car won't start [Re: OzHemi] #563947
12/31/09 08:23 PM
12/31/09 08:23 PM
might open up the pertronix as it could be somthing simple right in front of you that you can easily deal with
Re: Car won't start [Re: OzHemi] #563948
12/31/09 09:53 PM
12/31/09 09:53 PM
rexus31 Offline OP
rexus31  Offline OP
Timing chain is brand new, less than 500 miles on it.
