Re: Carb for 500 Mopar Performance stroker motor?
[Re: 1AARCUDA]
#563175
12/26/09 08:26 PM
12/26/09 08:26 PM
Posts: 502 North Texas
1AARCUDA
North Texas
Any discount on that Carb for Moparts members BIGS?
1970 AAR CUDA
1970 Super Bee 383 Auto
1969 Super Bee 383 4Spd
1968 Satellite 500 Stroker
1986 Shelby GLHS
1970 Coronet 500 383 Auto
1996 Indy Pace Truck
1998 Dakota R/T 408 Stroker
[Re: 1AARCUDA]
#563177
12/26/09 10:09 PM
12/26/09 10:09 PM
1AARCUDA
North Texas
Ok Jessie, I'll call you monday, looking forward to talking to you about my set up. I just signed up for Pink All Out here in Dallas, So I need to go fast, I will give you some free advertisement! talk to u then, and I know ur cutting me a good deal thanks for that.
1970 AAR CUDA
1986 Shelby GLHS
Re: Carb for 500 Mopar Performance stroker motor Update
[Re: 1AARCUDA]
#563182
01/22/10 11:56 AM
01/22/10 11:56 AM
1AARCUDA
North Texas
Well I took your advice and tore the motor down, Found a broken lifter, I have a new question, since this was a Purple shaft cam and lifter set up, Can I replace the one bad lifter with a stock lifter from the parts store? Also ordered my carb from Jessie at Bigs and waiting for it to come in.
1970 AAR CUDA
1986 Shelby GLHS
[Re: 1AARCUDA]
#563183
01/22/10 10:08 PM
01/22/10 10:08 PM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
Seems like you should be able to go with a stock replacement lifter.
The motor in the coronet started life as a 500" crate motor, same one you have. The guy who built the car immediately changed out the heads for eddie RPMs and the cam for a comp XE294H, .519/.526 lift, 250/256 @.050, 110 LS cam.
With that set-up, with 31" tire, 4.30's, 9.5" PTC that flashed 4200 it went a best of 11.49 @ 118. Was running a 950hp carb.
Since you have it apart, cc the heads and calc the actually CR, 'cause as far as those pistons are in the hole, I think 9:1 is pretty optimistic marketing on MP's part.
All that's left of the crate motor for me now is the block, crank and rods. Brian (ou812/IMM) built me a new mill last year with victor heads, roller cam and Ross slugs, 13:1.
I've still got the comp cam and lifters if you want to replace the 509. Drop me a pm if interested.
