Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563175
12/26/09 08:26 PM
12/26/09 08:26 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Any discount on that Carb for Moparts members BIGS?
1970 AAR CUDA 1970 Super Bee 383 Auto 1969 Super Bee 383 4Spd 1968 Satellite 500 Stroker 1986 Shelby GLHS 1970 Coronet 500 383 Auto 1996 Indy Pace Truck 1998 Dakota R/T 408 Stroker
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563176
12/26/09 09:57 PM
12/26/09 09:57 PM
Wisconsin
BIGS Offline
BIGS  Offline
Wisconsin
Hey Adam.....if you buy it from us over the phone and not threw E-Bay I will give you another $25 off.....Because we dont have to pay the E-bay fee's then so I can pass that on to you....This $599 with FREE s/h is already a pretty killer deal compared to a Holley HP out of the mags... ..Jesse @ BIGS!!
Jesse & Lynn BIGS Performance Products Building Street/Strip Carburetors since 1974 www.bigsperformance.com
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563177
12/26/09 10:09 PM
12/26/09 10:09 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Ok Jessie, I'll call you monday, looking forward to talking to you about my set up. I just signed up for Pink All Out here in Dallas, So I need to go fast, I will give you some free advertisement! talk to u then, and I know ur cutting me a good deal thanks for that.
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563178
12/26/09 11:01 PM
12/26/09 11:01 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
that is an excellent choice. I am very happy w my bigs carb
Re: Carb for 500 Mopar Performance stroker motor? [Re: Joshs68] #563179
12/27/09 10:26 AM
12/27/09 10:26 AM
Wisconsin
BIGS Offline
BIGS  Offline
Wisconsin
OK Adam.....talk to you on Monday....that will be great.....
Thanx allot for the support Josh.....Have a Happy New Year!! Jesse @ BIGS!!
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563180
12/27/09 10:41 AM
12/27/09 10:41 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i had a similar build in mine but with 4.30 gears and the car would have liked more convertor than the 3K stall so i feel a 4500rpm would have been better.mine liked the top end rpm.[6800 to 7000 gained 3 mph 113/12.30 et]i would think about advancing the cam also depending on where it is installed.[104 ICL]
nice car.mine is a satellite also.
Re: Carb for 500 Mopar Performance stroker motor? [Re: blownzoom440] #563181
12/27/09 10:37 PM
12/27/09 10:37 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I run a Mighty Demon 850 w/annual on my 500" 575hp crate engine. Works very well
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Carb for 500 Mopar Performance stroker motor Update [Re: 1AARCUDA] #563182
01/22/10 11:56 AM
01/22/10 11:56 AM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Well I took your advice and tore the motor down, Found a broken lifter, I have a new question, since this was a Purple shaft cam and lifter set up, Can I replace the one bad lifter with a stock lifter from the parts store? Also ordered my carb from Jessie at Bigs and waiting for it to come in.
Re: Carb for 500 Mopar Performance stroker motor Update [Re: 1AARCUDA] #563183
01/22/10 10:08 PM
01/22/10 10:08 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Seems like you should be able to go with a stock replacement lifter.
The motor in the coronet started life as a 500" crate motor, same one you have. The guy who built the car immediately changed out the heads for eddie RPMs and the cam for a comp XE294H, .519/.526 lift, 250/256 @.050, 110 LS cam.
With that set-up, with 31" tire, 4.30's, 9.5" PTC that flashed 4200 it went a best of 11.49 @ 118. Was running a 950hp carb.
Since you have it apart, cc the heads and calc the actually CR, 'cause as far as those pistons are in the hole, I think 9:1 is pretty optimistic marketing on MP's part.
All that's left of the crate motor for me now is the block, crank and rods. Brian (ou812/IMM) built me a new mill last year with victor heads, roller cam and Ross slugs, 13:1.
I've still got the comp cam and lifters if you want to replace the 509. Drop me a pm if interested.
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563184
01/22/10 10:36 PM
01/22/10 10:36 PM
Nelson-New Zealand
BIG-MIKE-500 ci Offline
Nelson-New Zealand
I have an Aussie Charger with a stroker 440(496ci)& 4-speed. Have Stock Stealth Heads,1:7/8" Headers,Comp Cams 294S(248@050)110 lobe centers,Wiend Xcelerator Manifold,10:1 Comp: 193 psi cranking pressure running on 96 oct: pump gas.
Have 2:75 gears out back & with myself & fuel on board it weighs in at 4100lbs & does 12:00@118+mph with an 850 Holley & with a 650 Holley does 12:3@116mph 1/4 mile.
Now,for the record,I run the 650 all the time on the street & it is just awesome. Pulls 6500 in 1st & 2nd,although it is starting to lay down about 5800rpm. What I'm getting at is the 650 Holley will run on the stroker.
Oh! & I also went on a chassis dyno & the 850 made 419 horse-power at the wheels & the 650 made 406 horse-power. The only other factor was, the torque on the 850 climbed more straight up.
Cheers, Mike in New Zealand.
