Source for epoxy for aluminum at 300 degree's ? #563134
12/26/09 12:36 PM
12/26/09 12:36 PM
Ridley Park, Pa.
69MOPE Offline OP
super gas
69MOPE  Offline OP
super gas
Ridley Park, Pa.
Need some epoxy to modify a water pump housing. Any recomendations?
Re: Source for epoxy for aluminum at 300 degree's ? [Re: 69MOPE] #563135
12/26/09 01:24 PM
12/26/09 01:24 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Most epoxies will patch fairly well. For building up
material for something exotic, TIG it.
Re: Source for epoxy for aluminum at 300 degree's ? [Re: 69MOPE] #563136
12/27/09 09:34 PM
12/27/09 09:34 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
http://www.devcon.com/products/products.cfm?appid=1&familyid=125
Maybe this stuff??
They have aluminum specific epoxies but the temp limit dry was only 250...
Re: Source for epoxy for aluminum at 300 degree's ? [Re: dodgeboy11] #563137
12/27/09 11:54 PM
12/27/09 11:54 PM
iowa
rook440 Offline
rook440  Offline
iowa
have you checked out the alumaloy rod on youtube ,it shows them welding an ear back on a transmission and repairing a hole in an aluminum can ,supposed to be tougher than aluminum when you are done ,you can buy it from ebay or eastwood , ...easy to use ,just a propane torch ,might be perfect for something like that /// good luck
