71 roadrunner clutch safety switch #561936
12/24/09 09:24 PM
12/24/09 09:24 PM
north wisconsin
shadow456 Offline OP
north wisconsin
can anyone supply a pic of correct way to hook safety switch to pedal? specifically does it need the plastic rivet and hook? or mount into the pedal lever? how does the hook go if needed? thanks
Re: 71 roadrunner clutch safety switch [Re: shadow456] #561937
12/24/09 09:39 PM
12/24/09 09:39 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
Is this what you want
Re: 71 roadrunner clutch safety switch [Re: gygeneral] #561938
12/24/09 10:20 PM
12/24/09 10:20 PM
north wisconsin
north wisconsin
yes ,thank you. does the overcenter spring only go one way?
Re: 71 roadrunner clutch safety switch [Re: shadow456] #561939
12/24/09 11:46 PM
12/24/09 11:46 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Re: 71 roadrunner clutch safety switch [Re: Snoopy] #561940
12/25/09 01:00 AM
12/25/09 01:00 AM
north wisconsin
north wisconsin
thank you.
