mopar cam 557? #561085
12/23/09 08:50 PM
12/23/09 08:50 PM
orange,tx
O
onebadstepside Offline OP
O
orange,tx
Whats the scoop on the mopar cam 296...557?What are ya shifting at?Combos and ET's are welcome...I know there are better cams out there,just wondering if its still a decent choice for a low buck 360
Small blocks rule!!!!!
Re: mopar cam 557? [Re: onebadstepside] #561086
12/23/09 09:02 PM
12/23/09 09:02 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
for a small block ,do you happen to know what this cam is at *50 ?
1.39 9.85 - 137 mph
Re: mopar cam 557? [Re: Ari440] #561087
12/23/09 09:03 PM
12/23/09 09:03 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
252 degrees at .050
Tony
70 AARCuda Vitamin C
Re: mopar cam 557? [Re: Ari440] #561088
12/23/09 09:05 PM
12/23/09 09:05 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Should be 251@50
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: mopar cam 557? [Re: onebadstepside] #561089
12/23/09 09:18 PM
12/23/09 09:18 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
Thats a fantastic budget camshaft! We used it in my brothers first small block. It shifted at 7200rpm with a 3.79 stroke. It also had box stock edelbrock cylinder heads and an M1 manifold. The car went 11.09 @ 118mph with that cam. With a 3.58 stock stroke 360 it should be more like 7400-7500 RPM with the similar parts used. It sounded great as well. Im not sure how well it would work in a heavy vehicle though.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: mopar cam 557? [Re: PUNK] #561090
12/23/09 09:29 PM
12/23/09 09:29 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
what compression would be mininum for the 557 cam ?
10.1 good ?
1.39 9.85 - 137 mph
Re: mopar cam 557? [Re: onebadstepside] #561091
12/23/09 09:33 PM
12/23/09 09:33 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Since I believe the DC/MP Solids all come from the same lobe "family"........
First the advertised duration is incorrect (for what we're all used to)
The seat to seat duration is given @ .015" not .020"
To find duartion @ .020", subtract 8º from what MP tells you.
To find duration @ .050", subtract 32º(intensity)from the answer you got from above.
So, a 296º-.557" is really 288º @ .020"/256º @ .050"
312º-.590.........304º @ .020"/272º @ .050" and so on.
https://board.moparts.org/ubbthreads/favl...amp;postmarker=
Re: mopar cam 557? [Re: S/ST 3040] #561092
12/23/09 09:49 PM
12/23/09 09:49 PM
orange,tx
O
O
orange,tx
Sounds like this cam is actually bigger than the advertised numbers.What makes cam pull so high in the rpm?
Re: mopar cam 557? [Re: S/ST 3040] #561093
12/23/09 09:52 PM
12/23/09 09:52 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
In the MP book they say to use .850 x advertized duration to find approximate .050 numbers for cams in the mild range.
It works pretty good for the most part up to the MP .590 cam
For me the MP cams below matched the .850 math
.484 @ 284 = 241 @ .050
.509 @ 292 = 248 @ .050
.557 @ 296 = 251 @ .050
and actually measured the same or very close.
But the MP .590 didnt
.590 @ 312 = 265.2 @ .050, it actually measured 272 @ .050
Reguardless, I like the All the MP cams above, the MP .557 is a good one. My measurements above were on the BB cams only. I assume, the SB lobe profiles would be the same. mike
Re: mopar cam 557? [Re: Sport440] #561094
12/23/09 10:02 PM
12/23/09 10:02 PM
S/ST 3040 Offline
S/ST 3040  Offline
My old 284º/.528" measured 244º @ .050"
The last 296º/.557" I checked was 255 and some change.
I have a 284º/.484" hydraulic but, I never plotted the lobes on it.
Re: mopar cam 557? [Re: S/ST 3040] #561095
12/23/09 10:45 PM
12/23/09 10:45 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
I had this cam in a 340. TRW stock replacement pistons. Box STOCK edelbrocks with 1.5 rockers. Went NO faster over 6000 rpm. Anything over that was just revving. Went 7.20's in the 1/8th in a '68 Barracuda. 3170lbs with 4.56 gear and 5000 stall. Good bracket cam.
Re: mopar cam 557? [Re: DaKuda] #561096
12/23/09 11:43 PM
12/23/09 11:43 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Used it in a low compression 440 and went 11.30's.Still have the cam and will use it again in a new engine.Shifted at 6500.
Nautilus Racing-
Re: mopar cam 557? [Re: DaKuda] #561097
12/23/09 11:44 PM
12/23/09 11:44 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My son and I both use the .557 Mopar cam in our cars. My buddy gave me mine and my brother gave us the one in my boys Dart which is a stock stroke .030 over 400. I shift at 6200 with my 906 headed 440 as it pulls nice up to that and I trap about 6400. I use 4.30's with a 30" tire. My son has Eddy heads on his 400 and he shifts at 6700 and traps about 6800 as he could use more gear (3.91's with a 26" tire) but it is a street car so we wont change the gears. His Dart weighs about 3550 with him in the car and my 63 goes just over 3700 with me in it. Both cars have run 11.40's. It is a nice street/strip cam for a mild build. Ron
Re: mopar cam 557? [Re: Ari440] #561098
12/24/09 12:17 AM
12/24/09 12:17 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The one I put in a 360 a couple years ago measured 255 @.050.
The car was shifted @ 6000 and went through @6200.Went a best of 11.78 in a 3400 pound street car.360 with ootb Edelbrocks.
The best street/strip small block cam I have personally ever used.
Re: mopar cam 557? [Re: Dunnuck Racing] #561099
12/24/09 12:26 AM
12/24/09 12:26 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
I will be putting a 340 together for a freind
10.1 comp , 540/235 (not sure), J head 2.02 m1 750carb
would the 557 be a good upgrade for this 340
its on a budget / low key combo
557 with 1.6 ratio rockers ,whats the lift ?
1.39 9.85 - 137 mph
Re: mopar cam 557? [Re: PUNK] #561100
12/24/09 12:28 AM
12/24/09 12:28 AM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
thats a bunch more RPM than that cam likes
my 69 dart 2970 lbs W-2 318 only turned 6,700 RPM to run 10.9s @ 121 the same cam in my 360 liked about 6,600 RPM ran 6.6s @ 104 1/8th its a nice cam makes good power for what it is and is verey mild manered if you want to run it on the street
Re: mopar cam 557? [Re: Ari440] #561101
12/24/09 12:29 AM
12/24/09 12:29 AM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
about .594
Re: mopar cam 557? [Re: W2DODGE] #561102
12/24/09 12:32 AM
12/24/09 12:32 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
about .594
thank you JOHN
1.39 9.85 - 137 mph
Re: mopar cam 557? [Re: Ari440] #561103
12/24/09 12:47 AM
12/24/09 12:47 AM
Northern Indiana
Northern Indiana
If you already have it,I would definately use it.
Mine was 10.3 to one,for what it's worth.
Re: mopar cam 557? [Re: Dunnuck Racing] #561104
12/24/09 01:06 AM
12/24/09 01:06 AM
Red Deer, Alberta
bill_greenwood Offline
Red Deer, Alberta
An alternative is the 284/528 with 1.6 rockers. I'm super tickled with mine.
