BENCH RACING: Holley 250 : 378 v.s. 446 #560960
12/23/09 06:51 PM
12/23/09 06:51 PM
Mid-Ohio
Bakaruda432 Offline OP
mopar addict
mopar addict
Mid-Ohio
I saw an article in one of the Mopar mags about using a B&M 250(now Holley) to get 600+ HP& TQ from 446 CID Mopar Big Block on pump gas.
Wouldn't using E-85 as the fuel for a 250 Holley Blown 378 Mopar Small Block allow this smaller mill to best the output of the 446?
Re: BENCH RACING: Holley 250 : 378 v.s. 446 [Re: Bakaruda432] #560961
12/24/09 02:58 AM
12/24/09 02:58 AM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
Perhaps if it was built to take advantage of it with high compression ratio, and higher boost. Better heads will probably help.
250 is too small for high hp numbers on a big engine.
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
