they use studs or bolt depending on what you run for exhast..mannys,headers,ect.
they are all in the water jackets,drain,remove bolt/stud seal with permatex copper and install,let cure over night
use liquid teflon,rtv,antiseize or the like to seal them
if they are studs and dont want to come out,heat with torch till they glow red and spray some JB Blaster to cool,it will wick into the treds and will come out when still hot
hope none break so easy does it on the R&R of them
there are 12 of them,you should seal all 12 this time around if they have not been done the first time,IMHO
