Re: Tips on restoring rim blow wheels
[Re: DAYCLONA]
#559292
12/28/09 11:37 PM
12/28/09 11:37 PM
Posts: 658 WOODGRAINWHEELS.COM Indiana
plumbeeper
Unlike the rimblow which has a tape stripe, the 68-70 A and B body woodgrain wheels used a stainless steel band on the inner and outer perimeter of the rim. If it gets scratched, it can be sanded out with 400 grit sandpaper and will look like new again. Also, with it being stainless steel, you don't have to worry about it rusting or tarnishing so you don't have to clear over it unless that's just what you want to do. I like the bands slightly exposed as well.
Now, to keep the DIY guys motivated, here's before and after shots of a 70 B body woodgrain we recently had in the shop.
Before
[Re: plumbeeper]
#559294
12/29/09 06:57 PM
12/29/09 06:57 PM
Posts: 2,758 Gilbertsville, PA 19525
Pntastar69
Dave, Mike, Jeff,
You guys have been very helpful. Hats off to Doug Lepak for offering some of his tips too.
1st time DIY'r so I started at it last night. Not a rimblow but a 69 A body. The wheel had typical surface cracks and 3 good size 1/2" splits, loose bands, the usual for a 40 year old wheel. Started grinding the top of the rim to remove material and looks like I see how ma mopar made these wheels.
Looks like they molded a base layer around the main rim, then glued the bottom (grip portion)onto the molded base. This portion has the recessed areas to accept the ss bands. Once the bands were set on place, the top layer was glued to the molded base which sandwiched the ss bands. These top and bottom layers are only approx. 1/8" thick but are curved on the inside the shape of the molded base.
I removed the top layer by slipping a small screwdriver between the top layer and molded base and it just fell apart in pieces, totally weathered and dryroted.
Anybody repoping just the top and bottom layers? The resto would be so much easier.
1st pic
[Re: AARCONV]
#559303
01/01/10 09:28 AM
01/01/10 09:28 AM
Posts: 427 WNY
slimert
WNY
Great info. Wish it was posted a few years ago... would have saved me some $$! I have done a few rimblow wheels and it gets easier like anything else with practice. Thanks for sharing Mike and Dave. Mike.
[Re: 79machocharger]
#559309
01/04/10 03:32 PM
01/04/10 03:32 PM
Posts: 5,135 Kingsburg Calif.
Quikshft
Kingsburg Calif.
Quikshft your grain looks great . What method did you end up using for putting in the grain?
I used/am using a very high tech tool for this work...a broken off hacksaw blade. I just ground the end to leave one complete tooth exposed. I also ground the sides of the blade to make the tooth a little bit narrower so the cuts weren't un-naturally large. Actually now, and a lesson here from experience, I should have used two different blades to get a little bit of dis-uniformity to the width of the grain cuts. Still, I'm satisfied and unless I get a little too picky I will probably leave it as is.
