wrist pin oil #558258
12/19/09 11:52 PM
12/19/09 11:52 PM
SW Missouri
MoparLore Offline OP
SW Missouri
What size wrist pin oil holes should I drill in my rods for floating pins?
Re: wrist pin oil [Re: MoparLore] #558259
12/19/09 11:57 PM
12/19/09 11:57 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
are you going to drill it on top or bottom? I think a small one like 1/8 but probably isnt that critical. I have seen them on top, but read that the bottom drilled diagonally is better. cant confirm.
Re: wrist pin oil [Re: pishta] #558260
12/20/09 12:00 AM
12/20/09 12:00 AM
SW Missouri
SW Missouri
Thought about drilling in the top and from both sides at an angle from the bottom. Chebby guy told me that worked well on his.
Re: wrist pin oil [Re: MoparLore] #558261
12/23/09 08:02 PM
12/23/09 08:02 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
According to the "hemi engines" manual [page 182], you can drill a 3/32" hole with a chamfer in the TOP of the rod when using floating pins. This is what I did.
Open the attachment for a picture
5685944-scan0001.pdf (171 downloads)
Re: wrist pin oil [Re: pacifica] #558262
12/23/09 08:44 PM
12/23/09 08:44 PM
drill a hole with a chamfer in the TOP of the rod when using floating pins. This is what I did.
me too (steel on steel floating). Not positive but iirc reading something about drilling the 2 holes at a 45 on the sides weakens the rod.
