8.75 rear question- What is that tube ?
#558212
12/19/09 10:25 PM
12/19/09 10:25 PM
Posts: 386 Maryland
reno340
Maryland
On my Duster's 8.75 rear axle housing I noticed this tube that sticks out of it on the top side of the axle tube (housing). It also holds on a brass block that the brake lines go in and out of. Anyway, I noticed that it was broken off. I did get the threads loose so I can easily get the remaining piece out. Is this some sort of vent tube (what is it's proper name?) and, more importantly, where can I find a new one? I really would like to put in a correct piece. Any help would be appreciated. BTW, My local salvage yard would not be of much help as they are picked pretty clean and if there was one, it is burried deep in overgrowth of bushes so they would be of little use for this part. ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games" - Earnest Hemmingway If you can't run with the big dogs, stay on the porch!! https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: 8.75 rear question- What is that tube ?
[Re: reno340]
#558214
12/19/09 10:31 PM
12/19/09 10:31 PM
Posts: 15,487 Florida
scratchnfotraction
yes,thats the vent tube with dust cap and it bolts the brake line Tee to the housing. may get one from napa or the dealer or JY or pick n pull yard ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: reno340]
#558216
12/26/09 12:27 AM
12/26/09 12:27 AM
Posts: 386 Maryland
reno340
Maryland
[Re: reno340]
#558217
12/26/09 12:39 AM
12/26/09 12:39 AM
RapidRobert
not sure but they might be the same on all axles if you have another one close by to check.
