Page 2 of 5 1 2 3 4 5
Re: where is my oil going? [Re: mickm] #557968
12/19/09 11:01 PM
12/19/09 11:01 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Spark plug tubes can cause oil consumption. They claim these work.
Re: where is my oil going? [Re: NITROUSN] #557969
12/19/09 11:07 PM
12/19/09 11:07 PM
California
mickm Offline OP
mickm  Offline OP
California
i have something similar.
Re: where is my oil going? [Re: mickm] #557970
12/19/09 11:17 PM
12/19/09 11:17 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That should take care of that issue. I would remove the pcv and vent from the covers. Plug one side cover start and run the engine. See if you have pressure or vacuum at the other cover. If vacuum you know the intake is still not sealing. There should be a small amount of positive pressure blow by gas. If there is a lot then you can be certain there is a ring sealing problem.
Re: where is my oil going? [Re: NITROUSN] #557971
12/20/09 01:17 AM
12/20/09 01:17 AM
California
mickm Offline OP
mickm  Offline OP
California
i'll do that next time i start it, and pull the carb and look for oil in the passages, and report back.
Post deleted by Defbob [Re: NITROUSN] #557972
12/20/09 01:29 AM
12/20/09 01:29 AM
Re: where is my oil going? #557973
12/20/09 02:40 AM
12/20/09 02:40 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Anybody think 8-10% is kinda high on a leakdown test? IIRC, 4% is about the most you would like to see. I'm sure you could run one that is worse than that and be fine but he is at double or more of that.
I want my fair share
Re: where is my oil going? [Re: SomeCarGuy] #557974
12/20/09 04:05 AM
12/20/09 04:05 AM
California
mickm Offline OP
mickm  Offline OP
California
dont' know for sure. i was told that somewhere around 4% was great for a race engine, 8-10% was somewhat average for a street engine with some miles on it.
that said, would be nice it if was better, but my understanding was that it wasn't bad either.
Re: where is my oil going? [Re: emarine01] #557975
12/20/09 09:51 AM
12/20/09 09:51 AM
Az
Crizila Offline
Crizila  Offline
Az
I would re check the intake fit, even if ya glue it good at higher rpm the crank case pressure can still push oil into the intake ports, you may need a thicker gasket or machine work to correct
One thing is for sure, from the pics, the ports and backs of the intake valves indicate lots of oil getting in there - way too dark for a motor with 6-7K on it. With that coloration, the inside of the PCV hose will be wet with oil if it is getting in that way. Are you sure the carnkcase isn't over filled??? Run it with the PCV blocked off and both valve covers open to atmosphere and see if the consumption stops.
Fastest 300
Re: where is my oil going? [Re: Crizila] #557976
12/20/09 12:58 PM
12/20/09 12:58 PM
California
mickm Offline OP
mickm  Offline OP
California
that is 64post's engine. i will find out if i have the same issue today...
Re: where is my oil going? [Re: mickm] #557977
12/20/09 02:04 PM
12/20/09 02:04 PM
It is not uncommon for the hemi motors to suck oil into the intake ports due to poor intake seal, one way to identify this is to let the motor idle for 5 to 10 minutes and pull a spark plug(if you have spark plug seals that work ) if there is oil on the plug after idling then it can be the intake seal. Try a thicker, better quality gasket or have the intake machined to make it fit squarely on the heads Have you check the intake fitment without a gasket to see if the space at the top of the intake manifold to the heads is the same at the top and the bottom on all four corners, top and bottom If not you may want to do that, it is not unusual for the intake to not fit properly after the heads are cut and the block decked and so on. Some of the motors from the factory weren't close to being correct
Re: where is my oil going? [Re: mickm] #557978
12/20/09 02:22 PM
12/20/09 02:22 PM
Boise
Moparteacher Offline
Boise
Install clean plugs, start-up cold (when smoking) shut off when still smoking, pull plugs and inspect. If it's cylinder specific you'll find it.
8-10% leak down on a new engine is too high assuming the test is done correctly. The engine should be hot. You may see 10% on a good engine if the test is done cold. False positive. The test is to be done at operating temperature. Get it good and warm 180+ and perform the leak-down.
The leak down only tests the compression rings for seal. The test does little for the oil rings.
When testing listen for leaking from crankcase (dipstick tube).
Re: where is my oil going? [Re: mickm] #557979
12/20/09 02:34 PM
12/20/09 02:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Borrow a gauge and put the hose on the dip stick tube
and run the car with the same set up you normally
run an see what the gauge says..... if you have pressure
it isnt evacuating even with the PCV and breathers
which would indicate a ring issue.... if you dont have
pressure its more likely to be a intake issue... a
leak check or compression check can not tell you
anything OUTSIDE of the cylinders(cant tell you if
the intake is sealed or not)
Also for a quick check.... change the PCV and make
sure its a V-8 one... there is one for a 4 banger also
Re: where is my oil going? [Re: mickm] #557980
12/20/09 02:42 PM
12/20/09 02:42 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Yeah John, pay attention you old fart...
I actually know why my ring seal is bad, I was posting the pics for Mick's benefit. If you notice in my pic the valley tray is segregated from the intake ports so it's impossible to suck oil from the valley.
Re: where is my oil going? [Re: Cab_Burge] #557981
12/20/09 03:57 PM
12/20/09 03:57 PM
California
mickm Offline OP
mickm  Offline OP
California
i did check the fitment of the intake. sitting in place with no gaskets the gap between the manifold and heads was nice and even all the way.
i sealed the intake according to tim banning's instructions, so i'm hoping that is good. i'm going to check that this afternoon, and if i fire it up then i'll play with some of the other things listed here and see if i can track this down.
Re: where is my oil going? [Re: MR_P_BODY] #557982
12/20/09 04:15 PM
12/20/09 04:15 PM
SomeCarGuy Offline
SomeCarGuy  Offline
That is good to know about the PCV. Will the 4 banger part even fit? What is different if it will?
Re: where is my oil going? [Re: SomeCarGuy] #557983
12/20/09 04:34 PM
12/20/09 04:34 PM
California
mickm Offline OP
mickm  Offline OP
California
and how do i know which is which?
Re: where is my oil going? [Re: mickm] #557984
12/20/09 04:56 PM
12/20/09 04:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
To look at them they look the same... but the flow/orfice
is larger on the V-8... you have to take the counter
guys word on it I guess
Re: where is my oil going? [Re: mickm] #557985
12/20/09 06:45 PM
12/20/09 06:45 PM
California
mickm Offline OP
mickm  Offline OP
California
so i took the rear carb off, and i found that rubbing my finger inside the intake, it came up slightly oily. not oily like rubbing your finger along the dipstick or something, just a minor oily film. i could feel that just about anywhere my finger could reach.
took the back carb off, (where the pcv is), and it seemed slightly less. remember that the front and rear of the manifold is connected by a cross over tunnel in the manifold.
wiping a swab down in the head portion of the intake port just came out slightly greyish, not particularly oily.
the pcv Is NOT closed at idle or partial throttle, up to 3-4k. this is no load though. it is open and sucking air, and when i put my finger over it, the idle drops.
i put a piece of tissue paper over the breather tied down with a rubber band. with the pcv in place there was negative pressure, it was sucked in a bit, as you would expect.
when i pulled the pcv out of the valve cover, no pressure on the tissue.
at idle there is some visible blowby. light though, i had to look to see that it was there, but once i saw it, you do notice it. higher rpm no visible sign.
sounds like at the very least i need a new pcv. i went to the local parts store, and no breather that will fit, didn't think to check for a new pcv.
Re: where is my oil going? [Re: mickm] #557986
12/21/09 12:20 PM
12/21/09 12:20 PM
California
mickm Offline OP
mickm  Offline OP
California
i'm going to look for a breather that will fit, and eliminate the pcv. that will at least tell me if it is directly involved with the oil consumption.
sound like a good plan?
Re: where is my oil going? [Re: mickm] #557987
12/21/09 12:35 PM
12/21/09 12:35 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I think 10% ona fresh engine is too high. Leakdowns tell you the condition of the compression ring.. the top ring.. But if the top ring isnt sealing gasses, the 2nd ring isn't scraping the oil well and the oil rings arent doing their job well either. Ona modern built moly ringed engine the cross hatch should barely be visible. The rings need a smooth finish to seat properly and they will show less than 4% leakdown if they have. IMO, yours haven't. If you disconnected the PCV and drove it for 50 miles you should see no drop in oil level if it's sucking past the valve. I dont think it is.
