Let's see your k-member carts #557834
12/19/09 01:49 PM
12/19/09 01:49 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
I am pulling the drivetrain as a whole with the K-member in a couple of weeks. I need some sort of K-member cart to wheel the thing around, and need to know what I should buy or build to make it happen. Thanks in advance!
Re: Let's see your k-member carts [Re: sharpie] #557835
12/19/09 02:05 PM
12/19/09 02:05 PM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
Really simple wooden frame. Possibly could have had some better castors but these ones I had in my garden shed did the job.
2002 Chevrolet Corvette 5.7 LS1 2011 Alpha Romeo Giulietta Veloce 1.6 JTD Because running a Mopar in the UK is getting TOO expensive!!
Re: Let's see your k-member carts [Re: Roppa440] #557836
12/19/09 02:07 PM
12/19/09 02:07 PM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
I fitted the trans at a later date so I only needed one to fit the engine and K-frame. Here it is having the body lowered over it. The headers were a tight fit between the frame rails but it did fit.
Re: Let's see your k-member carts [Re: sharpie] #557837
12/19/09 02:07 PM
12/19/09 02:07 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Hi Brian, just went through that sort of thing last summer. Just get some square stock (like trailer hitch size), weld up a cradle for the "K" frame. Put some casters on it, then make up a flat stock metal with an adjuster length of square stock welded on it (to attach to the area of the trans cross member). At the bottom weld a caster so the trans will role with the engine. To take the whole thing out as an assembly (eng, trans, "K" member,
and suspension)just unbolt the four main "K" member to frame bolts and lift the car off. Let me know if you need help.
Mike
The wood thing looks good too.
Re: Let's see your k-member carts [Re: sharpie] #557838
12/19/09 02:12 PM
12/19/09 02:12 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Re: Let's see your k-member carts [Re: 64Post] #557839
12/19/09 02:22 PM
12/19/09 02:22 PM
Elk Grove, Calif.
Elk Grove, Calif.
I really like that set up Dave, I think I'll build one like that. 'Cause mine is borrowed anyway.
Re: Let's see your k-member carts [Re: 64Post] #557840
12/19/09 02:23 PM
12/19/09 02:23 PM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
Another simple wooden one. Buddy of mine.
Re: Let's see your k-member carts [Re: Roppa440] #557841
12/19/09 02:59 PM
12/19/09 02:59 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Carts??
We don't need no stinking carts !!
When in a crutch, use one
Troy getting parts for his Hemi Dart clone.
Re: Let's see your k-member carts [Re: bigblock340power] #557842
12/19/09 03:07 PM
12/19/09 03:07 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I copied mine from this one. The T section is 4" square tube and the telescoping tail section is 3.5" square tube. If you're going to use a cherry picker to lift the body make sure the cradle isn't too wide.
