Re: hydrogen injection
[Re: 70Cuda383]
#557226
12/23/09 11:22 PM
12/23/09 11:22 PM
Posts: 4,647 aotearoa
rebel
aotearoa
Links? videos? press coverage?
he has video of all the tests but until he has everything patented we will not be seeing anything till probably march. thats understandable as he doesn't want someone stealing his invention. i'd be the same. BUT i did find out it's not a steam vapour or the like but a true gas. he disconnected the hose off the water tank & put it into a ballooon & then started the car. the balloon started to inflate resonably quickly, not as fast as we could blow it up by mouth, but still it inflated at a steady rate & when we let the gas back out the ballooon was totally dry, no sign of any moisture at all. when the gas came out of the ballooon we held a lighter in front of the stream of gas & that lighter flame grew real big real fast. i dropped the lighter in fear of burning my fingers. unstandably there will be disbelievers until it's released on the market as a certified addition to a combustion engine. the technology to actually do the extraction only became available last year so all previous inventions are stoneage by comparision. the emmissions test which i was shown, show the bmw runs at 1.2 on whatever scale they test on & with the hydrogen connected it dropped to 0.15. i'll admit it's over my head but seeing is believing. i've been told to go get a nos plate so we can do the adaption onto my engine for next season. so whats a good nos plate on the market?
[Re: rebel]
#557227
12/24/09 12:01 AM
12/24/09 12:01 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
well...if your friend really did find a way to defy the laws of physics, good for him. He's about to be a very rich man, and if I were him, and this was real, I too would be keeping very tight seal on everything until AFTER I got my money.
Good luck with it. (I still don't think there is any merit to this system, and that there's no way it will ever work)
**Photobucket sucks**
[Re: DakFink]
#557228
12/24/09 04:12 AM
12/24/09 04:12 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
yes that may be all true!! But you miss the Energy Potential of each fuel!!
Oxygen and Hydrogen pack a lot of energy potential in a small quantity.
As far as robbing energy from the alternator? What do you think it is doing the whole time the engine is running??? It is sitting there spinning whether you tap into it and use the electricity potential or not, it will set there spinning. It doesn't disconnect and take a break. Far as I see it letting it spin and not using it is more of a waist!!
Yes I have hear Alternators cause an engine to load up. And in each instance it is because the alternator was being overloaded itself. (Usually after a Dead battery, or external accessory was plugged in) Use the right size and you have no worries.
Ever hear an engine slow down a little at idle when the heater fan and lights are all turned on? Or the difference in idle speed when cooling fans kick on? Or when hooking up the jumper cables to that car with the dead battery?
That's the difference between an alternator just spinning, and being loaded.
All energy pulled out of an alternator comes from the crank, via the belt drive. Regardless of the temperature of the alternator.
It's been many years since chemistry and physics classes, but I can still recall this: molecules which release energy when they combine will take energy to break back down into their elemental components. If you don't want to take MY word for it, go look this stuff up. Or just ask someone who knows. You'll find 'em in any 200 level chem class at any reputable college.
Ask how much energy is required to separate O2 + 2XH2 from 2X H20. Then ask how much energy is released from combining that same amount of oxygen and hydrogen. And, how much energy is required to kick said reaction off.
If we could make MORE power by burning hydrogen than what it takes to break the water produced back into hydrogen and oxygen... we'd better throw all the laws of physics as we know 'em out the window. Because we'll have disproved the law of conservation of energy.
Oh, and probably made ourselves rich enough to buy Bill Gates, Steve Jobs, and any half-dozen Saudi princes as our butler, gardener, and cabana boys. ![](/ubbthreads/images/graemlins/beer.gif)
The only plausible benefit I can imagine is that the oxygen and hydrogen released by the browns gas system is able to facilitate a cleaner/better/more homogeneous burn in the combustion chamber.
Oh, and it facilitates 'internet urinating contests'. But that's okay, since I've been drinking water all day, and just had a big cup of coffee...
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: jamesc]
#557229
12/24/09 09:36 AM
12/24/09 09:36 AM
Posts: 482 Dirty South, MS
mopowered
Dirty South, MS
i just love it when people claim to have defied the laws of physics... perpetual energy...sorry guys not today
I must have missed something but I didn't read that anyone claimed to do any such nonsense. If I'm not mistaken, the idea of increasing fuel economy by hydrogen injection is the topic at hand.
After you have seen hydrogen gas melt rocks and explode with a flame travel speed of over 10 times that of gasoline - you might start to step out of the box your mind has you in.
[Re: mopowered]
#557230
12/24/09 09:49 AM
12/24/09 09:49 AM
Posts: 8,165 Left Coast
BobR
Left Coast
No the topic at hand is deriving the hydrogen gas from water-which is much more difficult and energy demanding than you seem to realize.
[Re: mopowered]
#557233
12/24/09 12:05 PM
12/24/09 12:05 PM
Posts: 4,213 New York
polyspheric
New York
you will find that it doesn't take much current to split water when delivered appropriately
Yes, there's a wide range of efficiency as to how the process is accomplished. The amount of energy used to separate water can be as high as (insert google number here) if you accidentally ground your power source, or some other foolish error. On the other end, it can be as efficient as to produce 99.99999% of the energy originally generated by burning the hydrogen - if you have an engine with a tiny little research lab inside with completely controlled conditions; otherwise, not. How do you get 100.000% of the energy back? When the laws of physics (inductance, entropy) are repealed. When do you get 100.001%? Never, not ever.
What's really sad isn't the people here who believe that: 1. you can get something for nothing 2. a demonstration can't be faked 3. even if it could, this great guy would never do that merely to get a lot of money
What's tragic is that some guys have actually paid for this rights to this "system" and invested their own money in trying to retro-fit cars with it as a business. Some of the reports (Youtube) are very depressing - the customers keep coming back and asking "where's the improvement?", etc. and the guy keeps making adjustments and excuses. His investment, career, and business end in bankruptcy, and alienation of his customers.
Boffin Emeritus
[Re: polyspheric]
#557234
12/24/09 01:57 PM
12/24/09 01:57 PM
BobR
Left Coast
Nuff said. The rest is just white noise.
[Re: BobR]
#557235
12/24/09 02:10 PM
12/24/09 02:10 PM
Posts: 3,160 L.I. N.Y. Hemi Street
HemiGreg
this topic is soooo misused I dont even know where to start cept see polys post theres no free lunch!!!!physics is phisycs. in my past life i worked with liquid and gaseous hydrogen and oxygen 5-9s purity as well as all the usual reox substances and can tell you that while getting HUGE!! power gains and energy outputs from combos, getting the pure forms and contaning and making use of that energy takes 3-5 times the consumed BTUs to make it work practly. yes I ran my lincoln on injecter H2 and also injected O2 and Acetone. it was killer power and still runs but all my supplies were (Free) like the wind farms making "free"wind power take sevweal million megawatts to produce the materials and equipt to erect them and the magnets in them produce tons of toxic waste which will last 1000s of years so in reality its just a shift of the problem not a true gain of anythine at all. the only "free power is when we heat our "free dead squirrel sandwich lunch in the sun on the ground. ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: mopowered]
#557236
12/24/09 08:35 PM
12/24/09 08:35 PM
Posts: 5,875 communist bloc of new jersey
jamesc
the last unit i worked (catalytic reforming unit) made hydrogen as a byproduct, about 1200 mscfh. the heater required to run the process was larger than most people's homes, fired at a rate of about 250,000,000 BTU per hour, had a stack 12 feet in diameter and about 125 feet tall. in other words it consumed enough energy to heat a good sized town. i don't claim to be an expert but afaik there are basically two different forms of hydrogen. H2 and electrolytic or atomic which is what you get from electrolysis, that is what's being discussed here. electrolysis of hydrogen is a net loss of energy, it takes more energy to run the process than the hydrogen it produces releases when burned. as for flame travel speed that's not necessarily a positive in an internal combustion engine. if it's too fast the flame front/shockwave will compress the gases in front of it severely enough to cause autoignition from the heat generated. then the two flame fronts will collide resulting in a thinning of your wallet due to replacing broken parts. internal combustion engines don't like detonation. everyone wants something for nothing it's just natural, it does however defy the laws of physics and to the best of my knowledge not a single one of these laws has ever been broken. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: jamesc]
#557239
02/10/10 05:24 PM
02/10/10 05:24 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
My head hurts from banging it against the keyboard... ![](/ubbthreads/images/graemlins/puke.gif) Ignorant people don't bother me. They don't know any better. It's the stupid ones that won't listen that kill me. Polysphere (and others) you guys have WAY more patience then I do. I did want to correct one thing that was mentioned though. Hydrogen does have more BTU's per mass then gasoline has. However it has MUCH lower BTU per volume then gasoline. Hydrogen under 10,000psi of pressure (in a 1 gallon container) has about 25% of the energy 1 gallon of gasoline has. Even liquid hydrogen only has about 1/3 of the energy. I'm going over to speedtalk to make myself feel better...
[Re: 70Cuda383]
#557241
02/10/10 08:20 PM
02/10/10 08:20 PM
Posts: 74 virginia
tigger1
virginia
Hydrogen is a fuel, it is not a hydrocarbon like methane or gasoline but it is still a fuel. Mix it with oxygen and it burns. If you set your carb lean and add hydrogen of course you will go farther. It is NOT better fuel mileage because you had to add fuel.
Twin turbo 440 72 barracuda
[Re: tigger1]
#557242
02/10/10 10:27 PM
02/10/10 10:27 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
If they had 15 cars every single day spend just $55 each then they can have the "initial" investment paid for in 10 years, this does not include maintnance, anual taxes, water, someone to man the place, insurance, electrodes that will wear out and will not be cheap...
I don't see them haveing 1 car a day any time soon and still not 15 cars a day in 10 years, remember back in 85 we thought we would be all flying around in our cars by 2015? I saw that in a movie so just another 5 years and it will be true! Oh yeah we will have hover boards instead of skate boards and food re-hydrators instead of microwaves.
[Re: HotRodDave]
#557243
02/11/10 12:06 AM
02/11/10 12:06 AM
polyspheric
New York
"The plan" isn't to get cars to run on more efficient hydrogen. It's to have the taxpayer subsidize the hydrogen stations. After that they don't care if there are any cars.
Boffin Emeritus
