? on cranking compression - cold new engine #556275
12/17/09 04:04 PM
12/17/09 04:04 PM
Alabama
Mopar-Al Offline OP
Mopar-Al  Offline OP
Alabama
Does 180 psi seem about right? New rebuilt engine, never been fired yet and still setting on a stand.
The build was 4.15 stroker, 440 source flat tops 12 in the hole, 906 heads shaved 60 or a bit more, 39 thou head gasket, lunati cam 60342 solid.
251/259 @50 106/114 center .377/.391 lobe lift useing 1.5 rockers.
I was shooting for around 10-1 compression, maybe a bit more.
Can anyone tell by the cold cranking psi if im in that range? I was shooting for 450 hp - 500 or so. Thinking about pulling the 6pk engine out of my car starting tomorrow and installing this. I do have some 110 octane here to start it up on if need be. I installed the cam on 106 int centerline. And useing ported 906 heads with 214/181's It's a 4spd 410 gear car, just to drive around local. Not a whole lot of Mopars at our local 1/8 mile track and I would like to have a respectable time for street tires with full factory exhaust. I have never really run an 1/8 mile much, always been 1/4 mile and in a race car. Hoping to get an 8? second pass in the 1/8th. My machinist friend has a 69 chevelle with a 454 and he ran an 8.23 street rim. I need to run as good= better than him. You think this set up is low 8 sec worthy? I had asked this before, but thought I may get a better input having a psi reading this time.
I was wondering if once the engine is broken in or warm if the psi number would get higher?
Re: ? on cranking compression - cold new engine [Re: Mopar-Al] #556276
12/17/09 04:14 PM
12/17/09 04:14 PM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
on the cam card there is some numbers needed, what are the numbers.
EX closes ATDC - IN opens BTDC
EX opens BBDC - IN closes ABDC
I dont see a problem running 8sec in the 1/8, if on street tires traction will be a issue.
Re: ? on cranking compression - cold new engine [Re: Sub95] #556277
12/17/09 04:37 PM
12/17/09 04:37 PM
Alabama
Mopar-Al Offline OP
Mopar-Al  Offline OP
Alabama
@ 50 says tappet lift
btdc 20 abdc 52 bbdc 64 atdc 16
Re: ? on cranking compression - cold new engine [Re: Mopar-Al] #556278
12/17/09 07:05 PM
12/17/09 07:05 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i would say your pressure is right where id think it should be. and you should be 8's in the 1/8
Re: ? on cranking compression - cold new engine [Re: aarcuda] #556279
12/18/09 12:35 PM
12/18/09 12:35 PM
Alabama
Mopar-Al Offline OP
Mopar-Al  Offline OP
Alabama
since this engine hasnt been fired up yet, is it possible that it may get a little higher? I seem to think no since all the rings are file fit and installed propper.
Re: ? on cranking compression - cold new engine [Re: Mopar-Al] #556280
12/20/09 03:27 PM
12/20/09 03:27 PM
Alabama
Mopar-Al Offline OP
Mopar-Al  Offline OP
Alabama
Today, I decided to spray a little oil into the cylinders and spin it a few revs to lube the walls a bit. The engine had set up with a cover on it for a few months. I also made sure the compression checker was seated good.
The readings I came up with this time were 200 and some were 205.
Does this still look like I can run 92/93 octane pump gas? Or maybe I have to mix with 110?
Re: ? on cranking compression - cold new engine [Re: Mopar-Al] #556281
12/20/09 03:56 PM
12/20/09 03:56 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
It will run fine on 87 at idle and light throttle,just run good fuel if you plan to push the throttle toward the floor.
