automatic trans question on later model A904
#556262
12/17/09 02:53 PM
12/17/09 02:53 PM
Posts: 2,581 Rutherfordton NC
BarryBum
Fruit Of The Loon
Fruit Of The Loon
Rutherfordton NC
This question is about a Jeep, but a lot of later model Mopars used this same tranny, so the question spans..... 97 Jeep Wrangler, 4 cyl, A904 automatic. I bought this Jeep yesterday with the assumption that the trans was bad. I've driven this thing probably 150 miles so far and the transmission shifts fine. It upshifts smoothly, downshifts smoothly....it runs great EXCEPT......when I start from a dead stand still and step on it pretty hard, it will shudder about 3 or 4 times before it takes off. If you drive it normally, it does fine........when it hits a little torque on a hard takeoff is the only time it does it....it just hit me, could it possibly be a broken trans mount?? I haven't even looked at that!!.....anyway, I went this morning and bout a new filter and new fluid, I was gonna try that, it does have 111,000 miles on it and I have no way of telling if the trans has ever been serviced. Any Ideas?
Re: automatic trans question on later model A904
[Re: BarryBum]
#556263
12/17/09 03:30 PM
12/17/09 03:30 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
what kind of fluid did you buy?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: BarryBum]
#556264
12/17/09 03:36 PM
12/17/09 03:36 PM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
What does it do when you put it into Man1? Any difference? This will help answer some questions.
" The last official act of any goverment, is to loot the treasury" George Washington
[Re: BarryBum]
#556266
12/17/09 04:52 PM
12/17/09 04:52 PM
zzyzxpat
Temecula, Ca.
It's hard to troubleshoot this without seeing it, but You do need to look for mounts or anything that would torque and hit any part of the body or frame. The only thing that could cause this in the trans would be the forward clutches breaking loose under heavy load. This is not a real common problem, but it does happen. You eliminated the low sprag by putting it into man1 and it still doing it.
[Re: zzyzxpat]
#556267
12/17/09 07:06 PM
12/17/09 07:06 PM
Posts: 15,487 Florida
scratchnfotraction
I had one do that before,was like the clutches or something was sliping and it would bang bang bang till you let off.. drive it easy and it was fine,just could not get it in a bind and torque it short while later it went out,the front band eat the drum up and it died I allways wondered if it was the over running clutch slipping the rollers or the clutch packs slipping or broke drum or drums slipped foward and eating themselfs up I know I seem to kill a lot of 904s and a few 727 with my driving wont hurt to start checking around for another one,just in case a rebuild needs some hard parts inside
[Re: scratchnfotraction]
#556268
12/18/09 10:09 AM
12/18/09 10:09 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
could it be the torque converter clutch going bad/not fully disengaging, bogging the motor down?
[Re: 383man]
#556270
12/18/09 09:11 PM
12/18/09 09:11 PM
zzyzxpat
Temecula, Ca.
They (rear clutches) are applied in all forward gears.
[Re: BarryBum]
#556273
12/19/09 10:45 AM
12/19/09 10:45 AM
zzyzxpat
Temecula, Ca.
If it is the rear clutches chattering, no, no adjustment. You may want to throw a gauge on it to see your pressures, but you will probably find that they are within range. The pressure tap is on the front servo, by the filler tube.
[Re: BarryBum]
#556274
12/19/09 07:23 PM
12/19/09 07:23 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
To isolate slipping clutches from a possible broken mount, place the shifter in 1 and stall the converter against the brakes.
