P/B clevis pin #555607
12/16/09 05:31 PM
12/16/09 05:31 PM
Southern Maryland
klunick Offline OP
klunick  Offline OP
Southern Maryland
Okay, perhaps a stupid question, but I am converting from manual to power brakes(Abody) and the one piece that wasn't with the old unit or came with my procured new unit was the clevis pin that attaches from the pedal assembly to the booster rod. I believe this pin is 3/8" but have no idea on the correct length. Can someone point me to where I can buy the right pin? Also, was this just regular steel or hardened, etc.
Kirk
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: P/B clevis pin [Re: klunick] #555608
12/16/09 07:26 PM
12/16/09 07:26 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Right you are on the length. I just got back from my Local ACE hardware...they have everything...as I am facing the same situation for my B Body. They were out of the 3/8 length ones so I had to settle for the 5/16 size and used washers for a spacer set up on each side of the clevis pin. It may not be "Correct" but at least no one will be able to see them any way and the entire engine bay is upgraded to all kinds of new stuff. Most home centers and good hardware stores will have the clevis pins in stock. Hope this helps. Oh...don't forget the cotter pins...
Re: P/B clevis pin [Re: CR8CRSHR] #555609
12/16/09 07:33 PM
12/16/09 07:33 PM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
Is this what you are looking for?? 74 B Body
Re: P/B clevis pin [Re: 268RTs4ME] #555610
12/17/09 12:15 AM
12/17/09 12:15 AM
Southern Maryland
klunick Offline OP
klunick  Offline OP
Southern Maryland
Yep. Length looks to be 1"? I guess I will have to hit ACE. I went online and it showed nothing. Only other thing we got down here is Lowes's and they show some "Adjustible" ones that have about 6 holes drilled in them. I have found some on-line also but it would cost more to ship them than they are worth. Oh, the joys of living in the bush!
