Page 1 of 3 1 2 3
Cast Iron Max Wedge headers #555394
12/16/09 02:01 PM
12/16/09 02:01 PM
Blanchard, OK
Real-Fury Offline OP
Blanchard, OK
Just wondering how the cast iron max wedge headers compare performancewise to standard aftermarket tubular headers. This would strickly be on a street machine. Car has 440 engine, mild performance cam, single 4bbl, A/T and fitted with max wedge headers and complete max wedge exhaust including factory cutouts. At least this is what I'm being told. I'm a rookie at this.
Butch
Re: Cast Iron Max Wedge headers [Re: Real-Fury] #555395
12/16/09 04:57 PM
12/16/09 04:57 PM
oregon
ramcharger1964 Offline
oregon
I would like to know this as well
I have a wedge motor with TTI 2" and full max wedge system but would like to know how much I would lose with a pair of the stock headers.
Hell B!tch Racing Co.
Re: Cast Iron Max Wedge headers [Re: ramcharger1964] #555396
12/16/09 05:07 PM
12/16/09 05:07 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Hey lots of guys are making good power with the regular 440 HP manifolds, some good 500hp builds there. I would say with those cast headers you wouldn't be losing out on much at all, other than weight!
Re: Cast Iron Max Wedge headers [Re: DaytonaTurbo] #555397
12/16/09 09:32 PM
12/16/09 09:32 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
the only problem is fitting them in the car
Re: Cast Iron Max Wedge headers [Re: Pool Fixer] #555398
12/16/09 09:36 PM
12/16/09 09:36 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
I would jump at that chance. No Tube header clearance issues, no header noise, no burned gaskets, sign me up. Too band I got a LA block now.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: Cast Iron Max Wedge headers [Re: Pool Fixer] #555399
12/16/09 10:25 PM
12/16/09 10:25 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Actually they fit better and have more clearance than HP manifolds.
Re: Cast Iron Max Wedge headers [Re: 62maxwgn] #555400
12/16/09 10:53 PM
12/16/09 10:53 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Will these fit on 68-72 B-Body? Anyone tried?
Re: Cast Iron Max Wedge headers [Re: Ply72rr] #555401
12/16/09 11:09 PM
12/16/09 11:09 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Up to 70 but you will have clearance problems with power brake booster.If you mill 3/16" off the manifold to head surface,driver side will fit,passenger side,no problems.Don't know about 71 and later.
Re: Cast Iron Max Wedge headers [Re: Real-Fury] #555402
12/17/09 09:18 AM
12/17/09 09:18 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
You'll need some extra horsepower just to overcome the weight.
This is the land of the free because of the brave
Re: Cast Iron Max Wedge headers [Re: rbstroker] #555403
12/17/09 09:36 AM
12/17/09 09:36 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Or go on a diet.
Re: Cast Iron Max Wedge headers [Re: 62maxwgn] #555404
12/17/09 09:59 AM
12/17/09 09:59 AM
How heavy ARE they? w flowing tubes & 3" outlet should flow good. I saw a pic of a big block in a 66 dart w them & it was an rb!. I have a mild 451 going into a 65 dart & am considering them but I want to run PS & I'm thinking they'll interfere . Any opinions on this??
Re: Cast Iron Max Wedge headers [Re: RapidRobert] #555405
12/17/09 10:30 AM
12/17/09 10:30 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You will have to use a Saginaw pump.The hoses need to go under the battery box.The Federal/Thompson pump have the pressure and return fittings in the wrong location.You will also need to change the return fitting on the centering valve.Use one from anything that used a Saginaw pump.It exits almost parallel to the box where the earlier is about 90* and interferes with the return hose being too close to the manifold.Took me a while to figure it out but everything now looks factory.
Re: Cast Iron Max Wedge headers [Re: 62maxwgn] #555406
12/17/09 10:33 AM
12/17/09 10:33 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Another
Re: Cast Iron Max Wedge headers [Re: Real-Fury] #555407
12/17/09 04:19 PM
12/17/09 04:19 PM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
MW manifolds will not fit in 66 and newer "B" body cars without cutting the firewall on the passenger side(RS). 62-65 "B" body cars had the engine located 1-1/2" more forward than 66 and later cars.
Re: Cast Iron Max Wedge headers [Re: Tom Swope] #555408
12/17/09 04:46 PM
12/17/09 04:46 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
that's what I thought too. I asked this same question years ago on moparts and a few guys with 68-70 B bodies chimed in and said that they had to do some trimming on the firewall.
One guy posted a pic of a drag car charger with the nose off. it clearly showed that these were kissing the firewall.
i still love them though and If I had the fab skills I would love to put a set in my charger. so cool..
Re: Cast Iron Max Wedge headers [Re: Tom Swope] #555409
12/17/09 05:11 PM
12/17/09 05:11 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
All you need is a big to pick up another inch!
Re: Cast Iron Max Wedge headers [Re: 62maxwgn] #555410
12/23/09 11:57 PM
12/23/09 11:57 PM
Maybe do the opposite swap of what the Early B-body guys have done for years?
Swap in a 62-65 K-frame in a later B?
Re: Cast Iron Max Wedge headers [Re: Real-Fury] #555411
12/24/09 12:10 AM
12/24/09 12:10 AM
PA
U
unclemike Offline
unclemike  Offline
U
PA
I had a set of those on my 1964 Plymouth Savoy with a 440 dropped in it. I can tell you that the hood gets a little on the hot side above the manifolds.
Also, I'm going to have to measure the engine in my 1964 and compare it to my 1968 because I was told the by a well know magazine writer that if I put the later cross member under my Plymouth the engine wold mount higher and further forward. That's opposite of what you guys are saying.
I have an old Hot Rod Magazine Spotlite book on the Max wedge cars. The cover photo includes a 426 stage three with the square tube manifolds that I personally have never seen on a production engine.
Re: Cast Iron Max Wedge headers [Re: unclemike] #555412
12/24/09 12:12 AM
12/24/09 12:12 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Your magazine writer needs a fact checker... Like many writers do...
Re: Cast Iron Max Wedge headers [Re: 1_WILD_RT] #555413
12/24/09 12:16 AM
12/24/09 12:16 AM
PA
U
unclemike Offline
unclemike  Offline
U
PA
The photo they used was probably from Chrysler, either a mock up or an artist's conception. The proof reader is retired by now as the book dates from the early sixties. Circa 1963/1964.
Page 1 of 3 1 2 3
