Bad rear lockup--prop valve or smaller cylinders? #55495
03/30/08 02:09 PM
03/30/08 02:09 PM
Willoughby Hills, Ohio
gd9704 Offline OP
super gas
gd9704  Offline OP
super gas
Okay, my other project for spring is to reduce the tendency of the Demon's rear tires to lock up under hard braking.
I bought the smaller wheel cylinder's from E-booger and was about to go that route--but my cousin who's much more auto-savvy than me told me that a proportioning valve on the rear brakes hard line would be a better way to go.....
What say you?
Greg
Re: Bad rear lockup--prop valve or smaller cylinders? [Re: gd9704] #55496
03/30/08 02:14 PM
03/30/08 02:14 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Rick Ehrenberg knows his stuff
nothing against your cuz.
there should already be a proportioning valve in place.
Re: Bad rear lockup--prop valve or smaller cylinders? [Re: gd9704] #55497
03/30/08 02:17 PM
03/30/08 02:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Either way will work but changing cylinder size is a guessing game while the adjustable valve takes the guess work out of it.
Re: Bad rear lockup--prop valve or smaller cylinders? [Re: John_Kunkel] #55498
03/30/08 02:25 PM
03/30/08 02:25 PM
gd9704 Offline OP
super gas
gd9704  Offline OP
super gas
True....and I would have the ability to fine tune it as well....
Thanks, John.
Re: Bad rear lockup--prop valve or smaller cylinders? [Re: bboogieart] #55499
03/30/08 02:40 PM
03/30/08 02:40 PM
gd9704 Offline OP
super gas
gd9704  Offline OP
super gas
I know Ehrenberg is the man.
The factory proportioning valve is in place.
The brakes work very well--but panic stops are very hairy--now with my wife and 2 year old in the car I worry about having to hit the brakes hard on the freeway......
My cousin was wrenching on these cars all through the 70s and 80s before they became "collector" cars. I respect his opinion on these things.
I like to get a number of opinions before I decide to screw something up!
Re: Bad rear lockup--prop valve or smaller cylinders? [Re: gd9704] #55500
03/30/08 03:34 PM
03/30/08 03:34 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
I just installed disc brakes on my 66 dart and used an adjustable prop valve to eliminate rear wheel lock up. This is the way to go as you can tune it for your specific car and its suspension and tires. After fine tuning mine it is amazing how good it stops.
Re: Bad rear lockup--prop valve or smaller cylinders? [Re: SCATPK] #55501
03/30/08 03:59 PM
03/30/08 03:59 PM
USA
CrAlt Offline
CrAlt  Offline
USA
Have you pulled the drums and looked at the brakes?
My dart started having a rear lockup problem... Then i pulled the drums and found that the leaky axle seals softened up the brake shoes and made them grabby.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: Bad rear lockup--prop valve or smaller cylinders? [Re: gd9704] #55502
03/30/08 05:25 PM
03/30/08 05:25 PM
MarkD Offline
MarkD  Offline
I put front disc rear drum on my Dart with an adjustable prop valve. I still need to go with the smaller wheel cylinders. The proportioning valve is adjusted out. That's why E man suggests the smaller wheel cylinders.
Re: Bad rear lockup--prop valve or smaller cylinders? [Re: gd9704] #55503
03/30/08 06:44 PM
03/30/08 06:44 PM
God's Country Maryland
GODSCOUNTRY340 Offline
In '68 &'69 Mopar used a delay valve to cure your problem. It was located just behind the proportioning valve. (pic). These were installed on High Performance vehicles. In '70 Chrysler redesigned the proportioning valve so this wasn't needed. It delayed the pressure to the rear brakes so they wouldn't lock-up first.
Re: Bad rear lockup--prop valve or smaller cylinders? [Re: GODSCOUNTRY340] #55504
03/30/08 06:46 PM
03/30/08 06:46 PM
Here's another pic in relation to the distribution block.
Re: Bad rear lockup--prop valve or smaller cylinders? [Re: GODSCOUNTRY340] #55505
03/30/08 10:31 PM
03/30/08 10:31 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
You really need to get the proportioning close w/o a valve (by juggling wheel cyl / caliper piston diameters, etc), then use the valve for the last 10% or so. Here's why:
The valve doesn't "cut in" - begin to work - until there a few hundred PSI of line pressure. So in rain, etc., it doesn't do anything. And, if the rear wheels are locked, the car will - MUST - spin!
Rick
Re: Bad rear lockup--prop valve or smaller cylinders? [Re: gd9704] #55506
03/30/08 11:32 PM
03/30/08 11:32 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
It took both to get my Cuda to stop to my satisfaction. Weight distribution and the relative grip of the front and rear tires all play a part in getting it right.
Re: Bad rear lockup--prop valve or smaller cylinders? [Re: Rick_Ehrenberg] #55507
03/31/08 08:19 AM
03/31/08 08:19 AM
gd9704 Offline OP
super gas
gd9704  Offline OP
super gas
Rick
Wow, thanks for the personalized response, Rick!
I guess I was hoping to avoid taking the rear brakes apart....but I guess this will be an educational experience!
Re: Bad rear lockup--prop valve or smaller cylinders? [Re: gd9704] #55508
03/29/09 11:42 AM
03/29/09 11:42 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Rear brakes are fairly simple. Spring tools will help make the job a snap. Do one side at a time so you have an assembled example. Check to ensure your drums are not heavily grooved, glazed or out of spec.
