Re: Bad rear lockup--prop valve or smaller cylinders?
[Re: gd9704]
#55497
03/30/08 02:17 PM
03/30/08 02:17 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Either way will work but changing cylinder size is a guessing game while the adjustable valve takes the guess work out of it.
[Re: John_Kunkel]
#55498
03/30/08 02:25 PM
03/30/08 02:25 PM
Posts: 1,180 Willoughby Hills, Ohio
gd9704
super gas
super gas
True....and I would have the ability to fine tune it as well....
Thanks, John.
[Re: bboogieart]
#55499
03/30/08 02:40 PM
03/30/08 02:40 PM
gd9704
super gas
super gas
Rick Ehrenberg knows his stuff nothing against your cuz. there should already be a proportioning valve in place.
I know Ehrenberg is the man.
The factory proportioning valve is in place.
The brakes work very well--but panic stops are very hairy--now with my wife and 2 year old in the car I worry about having to hit the brakes hard on the freeway......
My cousin was wrenching on these cars all through the 70s and 80s before they became "collector" cars. I respect his opinion on these things.
I like to get a number of opinions before I decide to screw something up!
[Re: SCATPK]
#55501
03/30/08 03:59 PM
03/30/08 03:59 PM
Posts: 9,887 USA
CrAlt
USA
Have you pulled the drums and looked at the brakes?
My dart started having a rear lockup problem... Then i pulled the drums and found that the leaky axle seals softened up the brake shoes and made them grabby.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
[Re: gd9704]
#55503
03/30/08 06:44 PM
03/30/08 06:44 PM
Posts: 2,499 God's Country Maryland
GODSCOUNTRY340
In '68 &'69 Mopar used a delay valve to cure your problem. It was located just behind the proportioning valve. (pic). These were installed on High Performance vehicles. In '70 Chrysler redesigned the proportioning valve so this wasn't needed. It delayed the pressure to the rear brakes so they wouldn't lock-up first.
[Re: GODSCOUNTRY340]
#55505
03/30/08 10:31 PM
03/30/08 10:31 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
You really need to get the proportioning close w/o a valve (by juggling wheel cyl / caliper piston diameters, etc), then use the valve for the last 10% or so. Here's why:
The valve doesn't "cut in" - begin to work - until there a few hundred PSI of line pressure. So in rain, etc., it doesn't do anything. And, if the rear wheels are locked, the car will - MUST - spin!
Rick
[Re: Rick_Ehrenberg]
#55507
03/31/08 08:19 AM
03/31/08 08:19 AM
gd9704
super gas
super gas
Rick
Wow, thanks for the personalized response, Rick!
I guess I was hoping to avoid taking the rear brakes apart....but I guess this will be an educational experience!
