What temperature do you guys run on your electric thermostat Switch ?
Mine is a 180* electric thermo switch that is in the intake heater hose outlet .. It just seems to turn the electric fans on too late .. 180*
is too hot for my SB. I would rather the Switch turn the Electric fans on around 160* -170*. I run a 160* manual thermostat . ..
Where do I find a lower degree thermo
switch ? All I can find out there is a 176* on 166* off switch .
Also ........ what are you guys running for a switch ?
Thanks in advance
:bow
