procharged hemi #554043
12/14/09 08:43 PM
12/14/09 08:43 PM
OHIO,CIRCLEVILLE
68DARTTURBO Offline OP
OHIO,CIRCLEVILLE
New project underway 4" stroke 4.5 bore aluminum block short block is under way! But whos hemi heads do i use,I am using a F3R procharger with a blowthru CSU carb. Any input on the heads like flow or who has the best rocker set up!Needs to live at the 6000 to 8000 range dont want to short cut valve tran.looking for the KISS method here.Was looking to use preditor heads but WOW the price is more than i can bare!11.000 dollars for what bad oiling issues not me for that price! If anyone can help please do.
Re: procharged hemi [Re: 68DARTTURBO] #554044
12/14/09 09:32 PM
12/14/09 09:32 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I would chat with Tim at FHO
for hemis only
Member the stig Jr has a Hemi with Millenium Heads and an F2
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Post deleted by Defbob [Re: Kam*Kuda] #554045
12/14/09 09:39 PM
12/14/09 09:39 PM
Re: procharged hemi #554046
12/14/09 10:12 PM
12/14/09 10:12 PM
OHIO,CIRCLEVILLE
OHIO,CIRCLEVILLE
they do have to be water heads
Re: procharged hemi [Re: 68DARTTURBO] #554047
12/14/09 10:29 PM
12/14/09 10:29 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
I would do stage v's. now weather you want to go with the millenium or the others would be up too you (id do the milleniums )
Post deleted by Defbob [Re: prochargedhemi] #554048
12/14/09 11:58 PM
12/14/09 11:58 PM
Re: procharged hemi #554049
12/15/09 06:55 AM
12/15/09 06:55 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
For the record I'm using the stock replacement stage v head.
My choice of head was decided by Tim at FHO
I agree with Fred also, on a blown application the millennium head is a waste.
Re: procharged hemi [Re: The Shadow] #554050
12/15/09 09:58 AM
12/15/09 09:58 AM
pa
572charger Offline
572charger  Offline
pa
stage v heads big valve stock exhaust and ray barton valve train !! T-Ds are the best !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: procharged hemi #554051
12/15/09 01:04 PM
12/15/09 01:04 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I made over 2100 hp w/turbos and stage v water heads 2.40 intakes. near any hemi head will make a whole bunch
This is an excellent post keep it going as I am in the process of building a twin turbo big inch HEMI myself. Still gathering parts as of right now. I have twin 106MM turbos a Keith Black stage 8 alum block Stage V water heads. I can only hope to make 2100 hp or more one of these days.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
