Re: IS THERE A DIFFERENCE IN BOOST??
[Re: Duner]
#553384
12/18/09 07:27 AM
12/18/09 07:27 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
Interesting.
I don't doubt your math, but it really seems like the addition of 1 bar of boost doubles the hp. Or at least that's what my results have pointed to.
I have rear wheel dyno pulls on the same vehicle on the same dyno - both with and without boost, with no other changes other than the addition of a Vortech SC and my home-built air/water intercooler. I got right at 300rwhp without the blower and 582rwhp with the blower - at a max peak of 16 psi boost. (it was more like a spike to 16 psi, mainly 14-15 psi the whole pulls) According to your math I should only be at 480rwhp?
What other factors could fit the results? Was the transmission just eating that much power that now with the increase the "robbed" power remains a fixed number and not a percentage? I know the blower was eating a bunch of power (125hp?) - since swapping to a turbo from the blower resulted in an 8 mph gain and a second quicker on actually less boost. I haven't had the turbo setup on the dyno.
All of this doesn't quite add up unless it's a matter of the parasitic losses being fixed numbers and not percentages. Am I screwing up the math by being able to get the intake charge temps below ambient? Why would my results be different than the math says it's supposed to be?
Because the math NEVER includes a figure for all variables and constants!!! If it did it would take 1/2 a day just to find all the numbers you need to plug in. I use CompCam's Dyno Sim just playing around and it covers alot more than most think about and from everyone that I have talked to that has built an engine and run the numbers through it, They say there is a 10-20% fudge factory, depending on how extreme the engine is.
Thats' why it's all theory, Rule of Thumb and plain old Guestimates until you get her on a Dyno or Down the track and even those 2 have a few flaws. At the end of the day your Timeslip is about as good as it gets!!!
[Re: jcc]
#553385
12/18/09 08:13 AM
12/18/09 08:13 AM
DakFink
Good points, but let me refine my question, does air under say at 60 psi flow different, and require a different design, then air on a NA motor? Not really asking about the volume, more does it behave differently, have different dynamics, and are they linaer differences, etc?
Yes!!! It does behave different under pressure than as a N/A engine. Now as far as the physics behind it and numbers and differences at 10 vs 20 vs 30 vs 60 psi. I won't even try to guess.
I will tell you this much. I read another discussion on Heads and Boost and there was a Head Porter that got involved in the thread.He said the heads he currently runs on one of his engines he ported for boost and knew it was a good design (proven on the track) but just out of curiosity sake he saw that the flow went flat at a certain lift and kind of stayed there. He was using the standard 28in/hg for vacuum on his flow bench. Being a boost guy and curious he cranked up the Vacuum to IIRC 36in/hg essentially imulating s ome boost. He said where he had a flat spot in his flow numbers picked up and continued to climb.
This leads me to wonder if this shouldn't be a new practice in Flowing heads especially when setting them up for boost. Why not try to imulate the real-world type of flow they will see as best as you can?? Or should there be a new standard vacuum point to use when using a flow bench??
I have noticed alot of heads seem to taper off around the same area of lift no matter the volume and design of the port. Is it the head or the Vacuum itself??
I know there is somewhat if a design difference in a Boost head than a N/A head because your not as worried about the turn radius and velocity through the port.
I've heard it put 2 ways for Boost Heads, Get as much flow as your wallet can stand. OR you want to see as much of the back of the intake valve as possible. Of course those are very general references.
Hope that helps!!! I try to refrain from throwing other variables in there. They are real world variable but most of them can be overcome, worked with or even used to your advantage.
Your doing the right thing!! Keep picking peoples brains!! there are hundreds of books out there written about Trubos and Turbo Engines and they for the most part are very good but as they always say " There is more than 1 way to skin a Cat"
[Re: jcc]
#553387
12/18/09 08:53 AM
12/18/09 08:53 AM
Posts: 22,724 Bitopia
jcc
Bitopia
1. In these applications we are nowhere near supersonic port speeds, right? 2. and when referencing boost as a measure of only port/valve restrictions, we are talking about a design that is less then 100% volumteric efficent? 3. And why can't a boosted motor be over 100% volumetric with different optimized ram tuning tricks, etc 4. or is it considered 200% efficent when using 14.7lbs of boost? 4. And efi has a better chance of charge cooling then a carb, depending on design/layout?
[Re: polyspheric]
#553389
12/18/09 10:39 AM
12/18/09 10:39 AM
Posts: 8,165 Left Coast
BobR
Left Coast
"real world vs. theory"?
Not quite. That's not a theory (global warming is a theory, Darwin is a theory), it's that quite different thing: a fact. There is no more "real world" than fact. Facts are still there even if no one believes them, they cannot be discussed (if I give up or change my mind, the gas laws are still the same way they've been for about 6 billion years).
Far too frequently, what people describe as theory (meaning "someone made that up, and it has nothing to do with actual parts"), what they're really telling me is "I can't distinguish between an opinion I disagree with (a theory), and a fact that I don't understand".
Attacking physics on the basis that someone who claimed to be well educated was wrong ("You sound like a guy I went to school with, always reading books - and couldn't make change for a dollar") is the same as "someone I know went to a doctor, and died anyway, therefore medicine doesn't exist".
No slight was intended but there are too many variables in this media for any hard and fast rules or formulas to be certain. I don't know what kind of experience you have with boosted high end applications but my life is saturated with it-the real world variety-going fast and winning championships. We don't use many formulas to get our car down the track. We test and take notes because that's what it takes to go fast.
[Re: jcc]
#553390
12/18/09 11:33 AM
12/18/09 11:33 AM
DakFink
Even if we do I don't see an Issue, only place I ever heard of Supersonic Stall is in Aircraft NOT Designed to go that fast and do. BAD JU JU!!!!
2. and when referencing boost as a measure of only port/valve restrictions, we are talking about a design that is less then 100% volumteric efficent? N/A engines are always less than 100% efficient. Efficiency is the difference of what is put in and what is given back out in return. In this case Air/Fuel in and HP/TRQ out.
3. And why can't a boosted motor be over 100% volumetric with different optimized ram tuning tricks, etc.
Most Boosted engines are 100%+ efficient
I'm not sure I would go that far!!!??? In some cases i could see it though!!!
Actually EFI has it advantages when dealing with boost because you can adjust the timing of Fuel and Spark delivery every 200-500 rpms across the entire RPM/Load range. Which in the case of 1 engine I saw that was prone to detonate at about 3000rpms and then smooth back out at 3500rpms. You could add more fuel or pull just a lil timimng in that area and maybe even pick up a few HP and not have any issues. Try that with a Carb and Distributor Ignition.
If your talking Aftermarket EFI, alot of systems also have 2-3-5 Bar MAP sensors and can also control boost.
[Re: BobR]
#553391
12/18/09 11:45 AM
12/18/09 11:45 AM
DakFink
This is the kind of answers I like to hear!! You can run all the Physics Formulas you want as many times as you want. But at the end of the day Timeslips and notes are the only real Numbers that will work for you.
Granted you do need to start somehwere nad work ut as many bugs as you can before you hit the track. But tere is always more to be had!!!
[Re: polyspheric]
#553393
12/18/09 02:01 PM
12/18/09 02:01 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
At 15 lbs of boost or 1 bar (however you wish to make it) you will effectively double horsepower
This has been repeated to death, and it's still not true. Yes, alllll the magazines have printed it, it's even on some blower websites.
It's that annoying "thermodynamic ratio of heats" thingy.
In brief: 1. no compressor is 100% efficient (although a good cooler can reduce charge temp below intake temp) 2. the gas expands and loses density just by virtue of being compressed 3. the difference in delivery volume between 2 pressures is the square root of their ratio. 14.7 ambient + 14.7 boost (assuming perfect, no temp, no para loss) is about +41%. (14.7 + 14.7)/14.7 = 2 2^.5 = 1.414, or 141.4% of original charge mass.
More info? Read my article: http://victorylibrary.com/supercharger/super-c.htm
I am unsure of why you quoted a "portion" of my reply and stated it was incorrect. I am looking to learn and have listed my complete reply to the post. You seemed to have listed the very same points I already listed yet I may have missed something. Can you reread and help me understand...
This assumes 1 No heat generated (Compressed air is heated thus less dense, it will happen thus intercoolers) 2 No Parasitic loss, (Roots superchargers the worst, Turbos the best) 3 100% Efficient Supercharger (they are all different with their own efficiency curves) and Turbos usually have some sort of lag as well
Factor the above and you reduce the doubling of horsepower by each of the percentages. (Please check my understanding here)
PV = NRT Pressure x Volume = Number of gas molecules X a constant X temperature
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Duner]
#553396
12/20/09 11:02 AM
12/20/09 11:02 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Interesting.
Forget math, forget laws of physics. Lets start with comon sense.
Even if you believe the 14.7psi doubles the HP hype, you're saying that not only did you double your HP from doubling the atm. But you also magically found a way to do it without any power loss from the blower?
I'm not saying that you didn't see it with your own eyes, but I am saying either...
1) The numbers weren't real.
or
2) You're not looking at everything.
Was the air/water intercooler filled with ice? If so, I guarantee that it would have made more then 300hp base to start with.
If it was EFI, was it run with the same injectors?
Because it's fairly obvious an injector sized for 600hp is WAY too big for a motor at 300hp. And if you did swap injectors, of course different injectors can make different HP with better/worse fuel spray patterns.
Obviously the whole intake tract was changed to swap from N/A to supercharger. What efficencies were gained there?
I'm sure you didn't just "Bolt it on" and gain 300hp. How much time was spent tuning the 600hp runs? If it really did pick up that much HP with boost and no tuning, doesn't that show how far off the original tune up was?
Fuel curve change/spark timing change/etc...?
I'm just saying, it's not as simple as the data you've provided. Saying that we tested it "back to back" is misleading.
I know you didn't mean anything bad by it, but there are a lot of things that could have (and probably did) change between those two tests.
Plus what about the cam? How many times have you guys watched a "Nitrous" cam car, make a run N/A? They are usually an absolute PIG. Same thing goes for blower/turbo.
Mismatched components on N/A (small cam/big head) would make the N/A HP way below where it should be. But the boosted stuff might take advantage of it.
All I'm saying is that there is a lot of unknowns when you do this type of testing.
In the end, the laws of physics still exist.
[Re: DakFink]
#553397
12/20/09 12:35 PM
12/20/09 12:35 PM
dizuster
Oakland, MI
As far as your comment on theories!! You live your ever day life revolved around a theory. "ELECTRICITY" It is nothing but a theory. There are Hundreds of Laws and Formulas that explains how it works, but to this very day there is no Physical FACT that that they are 100% correct. Physicist and Chemist stil to this day do not no for sure whether electricity flow + to- or - to +. In the Navy's elctronics schools both theories are taught to cover all bases.
What planet do you live on? Stop typing on your computer immediately. Electricity is just a theory and could blow up your keyboard at any second.
Somehow I doubt the Navy teaches two completely opposite aproaches to electronics (one well known, documented, and used vs. another abstract idea that hasn't been seriously concidered in 100+ years)
And what point did he say electricty was a theory? Weren't we talking about Gas Law's?
As for that article: Not too impressed. He states that Atmospere not Vacuum fills and engine and then immidiatelt starts talking about vacuum from the egine. (so which is is?) It is both. Vacuum and Pressure are both created by a difference in pressures. If an engine was only filled by atmosphereic pressure you probably wouldn't get muh if any air in the cylinder with the valves openeing and closing 1000's of time per minute. Now add the vacuum (difference in Pressure) that the cylinder creates as it makes a void on the down stroke and you will get some air forced into the cylinder as the valves open.
Atmosphere IS what fills the engine 1000's of time per minute. No different then the way we breath. Your diaphram muscle lets up on your empty lungs, and the atmosphere fills them back up. Vacuum is just a measurement. It's not a physical thing. Vacuum is simply the pressure differential between the atmoshpere and the chamber.
The reason he uses "vacuum" in the text instead of "Atmosphere" is because it's the only relavent measurable thing when you're talking about N/A motors. Gauge pressure is always relative to atmosphere. Measuring pressure relative to outer space, or the depths of the ocean wouldn't make sense. You need to measure it relative to the atmospheric pressure you are dealing with at the time.
Exhaust Back Pressure: I am adressing this cause this is the second mention I have seen. Yes you will have more exhaust back pressure with a Turbo, BUT this will not effect the engines output as a Turbo Cam correctly designed does not let exhaust gasses get pushed back into the cylinder. In fact most turbo cams will make you wonder what the plans are because the specs are usually way smaller than a N/A or even a S/C for the same power levels.
It will ALWAYS rob power, no matter what the cam design. You could leave the exhaust valve open forever, it still doesn't escape the fact that the turbo exducer is being spun by the gas pressure. In a turbo cam you don't ever really need to worry about the exhaust backing up. You need to worry about getting it all out first!
ATMOSPERE: I'll address this one as well since that article wanted to get all Physics BUT left alot of details out. ATMOSPHERE= 14.7PSI or 1-BAR 0r 29.92 IN/HG @ sea-level on a Standard Day. Standard Day= 70*F and 70%.
The second sentence in the article states,
"Atmospheric pressure, not vacuum, is what fills an engine with combustible mixture to be burned. This is about 14.7 lbs. per square inch (29.92 inches of mercury) at sea level."
What are you trying to say...He's right? What exactly did he leave out? And guess what. 14.7psi is 14.7psi at any temp. 70 degree's or 1000 degrees.
I see what the article was getting at and I will agree that you get more bang for the Boost at 7,8,10,12 psi than 15psi. You can usually make about 50-60% extra HP @7-8 psi and about 70-80% @ 10-12. And you'll be lucky if you get into the 90% range solidly with 15% on most street engines. That is why they call it a Rule of Thumb, NOT a BOOST LAW of physics!!
You see what he's getting at, but you obviously don't understand it.
When you physically reduce the space air occupies, you see a higher pressure reading on the gauge. Part of this from compressing the molecules (this is the good part that makes power) and part is from heat (this is the part that doesn't make power).
You can NEVER have all boost increase from compression alone, it always has heat involved.
[Re: dizuster]
#553398
12/20/09 01:08 PM
12/20/09 01:08 PM
Posts: 1,969 Chandler, AZ
Duner
Chandler, AZ
I think I did have power loss to drive the blower. That would be the big improvement on the switch from the Vortech to the Turbo.
I tested that. The first dyno pulls were with the Vortech Airhat in place with no intercooler. It made 512rwhp without intercooling and 537rwhp with it... before other tuning tweaks. There's NO question about the DA we run in here in AZ usually stinks. Boost plus lower than ambient IATs makes up for some of it, but that's why they have corrections to the dyno numbers. I don't get any corrections on the timeslips. 14.0s @ 97 mph NA vs 11.80s @ 120 mph with Blower. All with the exact same factory original rotating assembly, heads, cam, intake manifold and throttle body. The runs aren't "back to back", but no other parts were swapped besides adding supercharger, airhat, aux fuel pump and FMU.
All dyno pulls and runs are in fact with the exact same injectors. Bosch FMS 24# injectors were installed way early on. I added fuel pressure with an Aux pump and FMU to work with boost. I'm still running the exact same combo now but with a Boost-A-Pump system and better pumps.
No changes there between the NA setup and Blower. All are with the same M1 2bbl intake and ported stock TB that came on the truck in '99. The cam, intake manifold and rockers with ported 1.92 heads is what it took to get from the original 200rwhp as stock to 300rwhp before boost. I had the PCM flashed to alter the fuel curves and spark timing when the truck was NA. I'm still running the exact same tune/flash but with Boost Timing Retard thru MSD.
There's no argument that the factory parts/settings were not optimal at all, but I'd already made all of those changes to increase the power by 50% before adding boost. I have been tuning/beating on this thing for years, and you are right. It wasn't just a bolt it on deal. The swap to the intercooler system dyno sessions netted 70rwhp with the cooler, injector timing and fuel pressure changes... but I'd made fuel sync and timing changes to get the most out of it when it was NA also.
Well now we're to the "meat" of it.
The blower and now turbo did in fact take advantage of everything it could find and DOES make up for inefficiencies. I have no idea what my original VE was, but it has to be better now. I have to believe that the factory throttle body and the 2bbl intake DID limit the HP potential when NA. Having boost pressure waiting at the back of the intake valve doesn't really care that much about your port job, intake manifold or throttle body all that much.
I'm still running the original cam (236 @ .050" .520/.520, 114° lsa) that was put in when NA, but now it's advanced 4° to work with the turbo spooling. Do those cam specs sound out of lime for it in NA application? (4,000# weight) How about now with the turbo?
At present, I'm running that cam, home ported 2.02 EQ heads, the same 2bbl M1, an F&B 50mm TB, with a balanced forged rotating assembly. Nothing else changed, but on 10 psi of boost it's going 10.70s @ 128 mph. I have to upgrade the fuel system to see what it does at 15 psi of boost again.
I'm not trying to re-write any physics books, but how many people have engines that are already tuned to maximum efficiency? Boost "fixes" those inefficiencies for the most part. The "math"..... does it matter? I'm just looking at timeslips.
[Re: dizuster]
#553400
12/23/09 03:19 AM
12/23/09 03:19 AM
DakFink
Join the NAVY and find out!! I did and remember sitting in a 2 day class in Avionics School learning about Electron Flow and Hole Flow theories. Even Ford teaches the same thing . My cousin who is a Ford Tech said they were taught the same thing.
Explain how a WAISTED GAS being used for something productive is ROBBING POWER??
everyone uses 14.7psi like it is a constant, they try to throw the "at Sea-level" in there to make it sound even more consistent. In reality the 14.7psi Atmospheric pressure is very inconsistent. Ask anyone that flies planes. I calibrate Altimeters on a regular basis and have to call the tower within 30 mins of starting my tests just to get the current DA setting to make sure my readings are correct. Aircraft altimeters have a knob built in just for this and pilots have to use it constantly.
Post deleted by Defbob
[Re: DakFink]
#553402
12/23/09 09:01 AM
12/23/09 09:01 AM
