I run the same combo , only difference being 4.562 bore/4.625 stroke , i take it this is the raised cam block? , i run the 605 on the street with no issue , only problems i've had have been with the indy spray bar setup , just gott pull the valve covers regularly to check pushrods , can be a pain when using the larger type MSD distributor (nitrous) , other issues being valve spring temp/cold start.
Are those pistons vertical or lateral gas ported? , only issues i see are the gas ports getting gummed up with street use.
Good luck , a few good parts in that motor.
![](/ubbthreads/images/graemlins/beer.gif)
