converting to rally dash 68 B body #552272
12/12/09 08:27 PM
12/12/09 08:27 PM
Back In Iowa
belv2vert66 Offline OP
Back In Iowa
I will be doing a 68 bee clone
How hard is it ? what all do I need, Non air car
I put an ad in the parts wanted but it seems to be hard to find anything 100% complete. I don't mind piecing it together but don't want to search for missing stuff for ever either.....
Re: converting to rally dash 68 B body [Re: belv2vert66] #552273
12/12/09 09:06 PM
12/12/09 09:06 PM
Mansfield,Ohio
moparrulzzz Offline
moparrulzzz  Offline
Mansfield,Ohio
Just done this on my car. You will need a Ralley Dash Frame. Standard is different. A/C and Non A/c are different as well. If you have no A/C then you will need a non A/C frame.
Dash harnesses are totally different as well.
I found a complete dash a while back for $1200 and let it go and pieced it together. I wish I had bought the complete as there are alot of small things different between the two. Even the glove box latches are different!!
Chuck
Before
After
